XGC75
Psia = pounds per square inch absolute. It's the difference in pressure between the reading and the pressure in space (nothing). Earth's atmosphere is 14.7 psia at sea level (or close to it).
Psig = pounds per square inch gauge. Since most mechanical pressure gauges can only measure the pressure with the ambient conditions as a reference, most gauges measure psig. A boost gauge measuring vacuum is measuring negative psig because it still uses that 14.7 psia as a reference point and subtracts from it (typically in units of in Hg though, but that's just a different scale).
The car's MAP sensor conversion includes the ambient gauge correction, so you read psia out the ECU. Whatever you read, therefore, is 14.7psi above the psig reading we usually refer to when we say "k03 boosts to 8psi stock".
Sent from my SAMSUNG-SM-G920A using Tapatalk
