The issue was made very clear once I got the car home and looked underneath. Oil drip pools just under the IC outlet to TB pipe. Peeking behind the splash shield, the IC hose had come completely disconnected. The T clamp was tight enough, but I was able to make it a bit tighter with the right socket. Boosts good now. No issues after that, but I was most definitely concerned all day. I figure they had to disconnect the TB hose in order to get to the DSG. Hopefully it stays put this time.Alright so on my way to work today on the highway. Switching over to the left lane to make a pass so I'm pushing the car a bit and suddenly a wooosh and loss of most if not all boost pressure. I was able to get to work and park but staring in from the top of the engine bay didn't yield anything too obvious. I'm at work so I can't dive under it right now. P3 gauge was reading super high boost levels at to moderate throttle so i assume this is a pretty massive leak. After a shut off and restart, car throws P0101 which indicates a bad MAF but I'm leaning to disconnected intercooler piping. I shook the intake to see if it was loose at all but it didn't seem like it.
For context, just had my dsg replaced as well as condenser, compressor, and evap. I thought that whoosh sensation was my new dsg slipping gear into oblivion at first but not likely given no obvious code. Sure was a serious drop in power. DV is old but it's not the diaphragm type DV. It's definitely the D valve revision.
Assuming I find nothing as an obvious culprit. Is there anything I can run in vcds to deduce the actual problem or where to start looking?
P2568
I put in a NEW clutch kit, if I don't drive the car, every day, will it damage anything? I know it is a stupid question...
I will drive the car every 5 days, need to recover the money I spent on the car >_<
I would highly suggest doing a ripper of a burnout in first and second before letting the car sit.I put in a NEW clutch kit, if I don't drive the car, every day, will it damage anything? I know it is a stupid question...
From my googling that code is really only associated with the radiator sensor? I guess you could monitor coolant temps and exhaust temps and see what they are doing.
Ok, perfect, I won't let it sit for too long because it's bad for the tires...From my googling that code is really only associated with the radiator sensor? I guess you could monitor coolant temps and exhaust temps and see what they are doing.
No it can sit.
LOL hey I already did some pulls up until 4K RPM, damn BMW's always wanna race, I stopped doing this, and I did some pulls under tunnels, it's so hard not to full send/WOT...I would highly suggest doing a ripper of a burnout in first and second before letting the car sit.
This is satire.
I got this one shipped to NZ. https://www.rockauto.com/en/moreinfo.php?pk=15710077&cc=1447793&pt=4932&jsn=2Hey mate, in the same boat here in NZ. which one did you go for at the end?
