brat_burner
Pretty sure it goes like this. Or just check the ones you take off.
jedred1
jedred1
jedred1
jedred1
Which SUV from VW do you all prefer? I would like to tow a small trailer and go on dirt roads to go fishing.
Phur
I have reached out to APR in the past. They said 0.028” and I’m only high torque 93 Stage 1 w/ CAI.
GolNat
Yeah for towing I’d go TDI (if you need to tow heavy stuff). If you don’t want to have to mess with diesel get one with a V6. If you don’t need to tow more then 2-3k pounds then I think the 4 cylinder will do it.
The older Gen Toureag is smaller then the newer one if you don’t need to carry a lot of people.
jedred1
jedred1
Mabey I'm running to big of a gap at 0.032" which I think is the stock (VW factory) gap. I am APR stage 2 should I regap them all?
snobrdrdan
former GTI owner
How do I assemble this shit. (Rear shock mount)
basically how does it all fit together with the shock?
Those are NOT MK6 rear shock dust boots or bump stops
I don't know why they include those....I'm pretty sure those are older/MK4 parts
You can reuse what you have though (the bump stop is attached to the rear plastic boot that slides up into the OEM rear shock mount), or buy new ones:
https://www.urotuning.com/products/...-a3-mk5-golf-jetta-r32?variant=31733862268983
https://www.urotuning.com/products/bump-stop-rear-118mm-mk5-mk6-eos-1k0511353n?variant=8391866220599
uglybastard
im not running bump stops with my coilovers right now, i forgot to buy replacements. oops.
smanierre
Welu522
I mean here’s the parts list right from Eibach.
Says 2010 GTI but I assume it’s all the same for MK6s
guess I shoulda mentioned these came from a Eibach pro kit. Doing a Koni and Eibach cup kit.
https://static.summitracing.com/global/images/instructions/eib-85109-140.pdf
jedred1
jedred1
Phur
I mean spec is closer to 18ftlb but as long as you can get it off...
I have mine pregapped for install this weekend. Was going to do yesterday but napped instead after work.
How old are you?!? 😁
