brat_burner
Pretty sure it goes like this. Or just check the ones you take off.
APR stage 2What tune are you running?
Toureag TDIWhich SUV from VW do you all prefer? I would like to tow a small trailer and go on dirt roads to go fishing.
I have reached out to APR in the past. They said 0.028” and I’m only high torque 93 Stage 1 w/ CAI.
You might see better top end power if you do.Mabey I'm running to big of a gap at 0.032" which I think is the stock (VW factory) gap. I am APR stage 2 should I regap them all?
Those are NOT MK6 rear shock dust boots or bump stopsHow do I assemble this shit. (Rear shock mount)
basically how does it all fit together with the shock?
im not running bump stops with my coilovers right now, i forgot to buy replacements. oops.Those are NOT MK6 rear shock dust boots or bump stops
I don't know why they include those....I'm pretty sure those are older/MK4 parts
You can reuse what you have though (the bump stop is attached to the rear plastic boot that slides up into the OEM rear shock mount), or buy new ones:
https://www.urotuning.com/products/...-a3-mk5-golf-jetta-r32?variant=31733862268983
https://www.urotuning.com/products/bump-stop-rear-118mm-mk5-mk6-eos-1k0511353n?variant=8391866220599
Totaledim not running bump stops with my coilovers right now, i forgot to buy replacements. oops.
I mean here’s the parts list right from Eibach.Those are NOT MK6 rear shock dust boots or bump stops
Ok, just regaped to 0.028" and it didn't blow up. Torqued to 22'# as usualYou might see better top end power if you do.
I mean spec is closer to 18ftlb but as long as you can get it off...Ok, just regaped to 0.028" and it didn't blow up. Torqued to 22'# as usual
How old are you?!?I mean spec is closer to 18ftlb but as long as you can get it off...
I have mine pregapped for install this weekend. Was going to do yesterday but napped instead after work.
