torga's Daily Build - black, 6mt, two-door shenanigans
torga
So a few days ago, I impulse bought a set of TT-RS front brakes. I fully intended to keep it simple and do a full R32 upgrade, but one night I just idly asked FB Marketplace if there were any TT-RS calipers in town.... and there were... for an absolute bargain. Especially in the condition they're in. They're practically flawless. I bought them from a guy who intended to put them on his B5 S4 but just never got around to it. Saw them on Sunday night, had them in my hands Monday after work.
Here are some photos.
Here are a few photos of them next to the R32 fronts I originally was going to use. The R32 calipers look CHUNKY compared to the TT-RS clamps.
For anyone curious about weights....
The TT-RS front caliper/carrier comes in at an even 9 lbs. and the R32 front caliper/carrier weighs 16.6 lbs. That's a huge difference! Almost a factor of two!
With my original R32 plan, I planned on doing StopTech slotted rotors all the way around. With the TT-RS fronts, the way I see it, I have three options:
Option 1: The Medium-Full Send
I stick with the solid StopTech slotted for the rear and I buy the crazy, 2pc full-floating Girodisc rotors for the front. I absolutely do not need these. But hot damn, are the Girodisc rotors sexy. Just eye-candy. Just imagine that setup behind the wheel. The full-send version of this plan would be buying the R32 2pc semi-floating rotors that ECS sells, for the rear.
Option 2: The Frugal Boy
I stick with the solid StopTech slotted for the rear and I buy OE rotor replacements for the fronts. Simple, get the job done. This would save about $400 in total over option 1. However, I've read that the stock rotors had a tendency to make noise with these calipers. Dunno how much of an issue this could be, though.
Option 3: The Understated Boy
Let's face it... 370mm front brakes on this car would definitely be excessive. I know, I know, it's my car, I can do whatever the hell I want with it. But for a more low-key upgrade -- and a cheaper rotor replacement cost down the road -- I could instead opt for this VAGBremtechnic carrier adapter, which brings these calipers inward to be usable with the 345mm rotors of the Mk5R32 and Mk6R. Then I'd pair them with the StopTech slotted rotors from before. This option only saves $300 over Option 1.
Saabingti
Lucky man! Those are beautiful.
What's the difference in rotor cost between Option 2 and 3? Could Option 3 pay for itself in the first replacement?
torga
F/R rotor replacement for option 2 would be about $800. The same for Option 3 would be about $600. For Option 1, F/R rotor replacement would be about $1,000.
I dont see a full-full send option?
Full-Full send is nested within Medium-Full send, at the end. Well, I guess Full-Full send would be to get the fully-floating Golf R rear rotors from Ceika. That's the only fully-floating 2pc I know for the R platform. Full-Full send would end up costing close to $2800, all said and done. WOOF.
Saabingti
So even though Option 3 is $100 more expensive up font compared to Opt 2, it's $200 cheaper per consumable replacement event. Math seems easy, but math doesn't ever take emotions or cool-factor in to account...
edit: nor does math take end performance goals in to account and those larger rotors might help with breaking force/heat. The 4pots on a smaller rotor may still be fine or more than fine for what you want but idk.
torga
If I were only concerned with math, I'd just be getting new rotors/pads and sticking with my stock brakes!
Saabingti
Very true! Hence the second sentence and the edit.
torga
I think that the smaller rotors would be more than fine for the soon-to-be track use -- this isn't a super heavy car. Solid rotors for learning and eventual 2pc for when I want more. So I should add that Option 2 will almost certainly end up leading to Option 1 when rotor replacement comes due. And Option 3 will likely have me get 2pc replacements as well.
torga
just get fake rotors and call it a day
I'll just weld on some more iron on my stock GTI rotors -- build up some diameter to meet the new calipers.
#BuiltNotBought
torga
Mirror photo op! I circled back around the parking lot just to nab this.
