torga's Daily Build - black, 6mt, two-door shenanigans
torga
Picked up a lightly used (seller claims ~1,000 mi) Tyrolsport Caliper Stiffening kit from eBay for just $45. Kinda didn't even think about it at that price.
csumt76
Nice. I was reading about some people's experience with those and stainless lines saying it was kinda so so. I only used lines on sport bikes and thought it made a massive difference in feel.
torga
I'll be getting stainless lines as well, but these are the solid caliper guide bushings to replace the OEM rubber ones. Some StopTech cryo-treated discs and StopTech 308 pads will round out my brake upgrade. Not looking to go full-tilt BBK just yet.
torga
Installed the APR pendulum mount and 034 inserts today. Getting the old ECS poly insert out required running around for 2 hours trying to rent an impact wrench and eventually buying one, then returning it later. I got scared because I sheared a 1/2" to 3/8" drive adapter with a breaker bar trying to get the bolt off and I didn't wanna deal with dropping the subframe because of a sheared bolt. Once I got the bolt off with the impact gun, I basically had to rip apart the ECS poly insert because it did not want to come out. Seems like a one-time use part and I'm glad I didn't spend money on it.
Once everything was uninstalled, the APR mount and 034 inserts went in very quickly. I ran a few errands after that and my shifts are engaging more reliably and smoothly - the biggest difference is in the reverse gear. As far as NVH, I can't notice any differences whatsoever between APR mount & 034 inserts vs stock mount and poly insert. Idle or street/highway driving, it felt great at all stages.
torga
Domo arigato, Boosted.
Probably taking a bit of a break other than tinkering here and there until I scrounge up enough money for a clutch. Big suspension refresh will follow shortly after that, if not at the same time. Still figuring it out if I want to use the RSR clutch or buy a DKM Stage 2 kit. I'm about 20/80, RSR/DKM. It'd be ~$1,400 for the RSR vs. ~$900 for the DKM kit, all before labor. That's a big jump for just some comfort.
zrickety
The Fixer
Looking good, Torga. Have you looked at the Sachs SMF kit? I've only heard good things, but when I was looking a few years ago it was only available from Europe.
torga
Thanks man!
That one's even more expensive than the other two I'm thinking about 😨
And doesn't hold as much torque as either of the other two.
The DKM is made in partnership with Competition Clutch, who has a great track record.
torga
It's more about how much torque I'll eventually run. I'll go K04 at some point and I wouldn't feel comfortable using 90ish% of the clutch's rating. Sachs is only rated for 520 N*m, which is 385 lb*ft. I'd feel more comfortable with more headroom - better for longevity too.
