Total Power Steering, Brake Assist Failure
Fleron2301
Hi all,
I'm experiencing an "ESP Error" everytime I start the car, with a brief moment of no power steering, and no/limited brake assist. What usually happens is that the power steering and brake assist happen for less than a second, and then I have no TCS or ESP for 1-2 minutes while driving. However, sometimes when I am taking a turn, my power steering will fail and the steering wheel will feel extremely heavy or jammed, and this has gotten me close to an accident in a moderate-speed turn. This is what VAGCOM says:
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 48292 km
Time Indication: 0
Date: 2014.11.13
Time: 17:24:59
Freeze Frame:
RPM: 1060 /min
Load: 48.6 %
Speed: 1.0 km/h
Temperature: 36.0°C
Temperature: 30.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 13.716 V
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BG HW: 1K0 907 379 BG
Component: ESP MK60EC1 H31 0106
Revision: 00H31001
Coding: 114B600C492B00FE881006ED92220041B70800
Shop #: WSC 01357 011 00200
VCID: 78D13FB4CB0FA3E157B-802D
3 Faults Found:
01309 - Power Steering Control Module (J500)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 6
Reset counter: 224
Mileage: 48211 km
Time Indication: 0
Date: 2014.11.12
Time: 00:54:17
Freeze Frame:
Count: 0
Count: 0
Count: 12800
Count: 8213
Count: 51457
Count: 1
Count: 250
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 5
Reset counter: 224
Mileage: 48211 km
Time Indication: 0
Date: 2014.11.12
Time: 00:54:17
Freeze Frame:
Count: 2
Count: 0
Count: 12800
Count: 166
Count: 51200
Count: 1
Count: 759
Count: 0
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 7
Reset counter: 224
Mileage: 48157 km
Time Indication: 0
Date: 2014.11.10
Time: 15:00:51
Freeze Frame:
Count: 2
Count: 4
Count: 12800
Count: 16390
Count: 50434
Count: 251
Count: 0
Count: 0
1 Fault Found:
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 48211 km
Date: 2014.11.12
Time: 00:54:17
4 Faults Found:
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 250
Mileage: 48211 km
Time Indication: 0
Date: 2014.11.12
Time: 00:54:17
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 250
Mileage: 48211 km
Time Indication: 0
Date: 2014.11.12
Time: 00:54:17
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 74 3201
Revision: 00H20000
VCID: 3449CB8457E78781BB3-8061
2 Faults Found:
02391 - Terminal 30 Reference
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 4
Reset counter: 9
Time Indication: 0
Freeze Frame:
Voltage: 7.50 V
PD
Temperature: 43.0°C
Speed: 50.0 km/h
Torque: 0.0 Nm
Torque: 0.000 Nm
Term 15 On
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 7
Mileage: 48413 km
Time Indication: 0
Date: 2014.11.16
Time: 06:15:09
Freeze Frame:
Battery Volts: 14.2 V
DU
Temperature: 28.0°C
Torque: 0.012 Nm
Torque: 1.6 Nm
RPM: 36 /min
Drive Current: -5.7 A
Thank you!
Fleron2301
I am still under the powertrain warranty, hope this is covered. Wondering where the sensors are? Last thing I did before this happened is the Tyrolsport Master Bracket. Intercooler 2 months ago, dropped subframe in June.
hummvee2134
It seems like a harness or ground issue judging by the open circuit errors. I'm not sure on the specifics on the wiring so it would be probably be best to work with a dealer.
victor247
Hi all,
Thank you!
Did you ever get this resolved? I'm getting the exact same codes!
ChrisB1
Same here:
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492580FC881206E6921C0141B70800
VCID: 7DDF1280E40441D636-8028
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 76
Mileage: 41541 km
Time Indication: 0
Freeze Frame:
Count: 16384
Count: 12
Count: 12800
Count: 8213
Count: 44800
Count: 0
Count: 0
Count: 10752
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 41541 km
Time Indication: 0
Freeze Frame:
Count: 16386
Count: 12
Count: 12800
Count: 166
Count: 45056
Count: 0
Count: 0
Count: 10752
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 76
Mileage: 41541 km
Time Indication: 0
Freeze Frame:
Count: 16386
Count: 12
Count: 12800
Count: 16390
Count: 51712
Count: 0
Count: 0
Count: 9472
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 3753C0A846B8AB86AC-8062
1 Fault Found:
01312 - Powertrain Data Bus
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 4
Fault Frequency: 2
Reset counter: 116
Mileage: 41541 km
Time Indication: 0
Date: 2015.10.17
Time: 20:32:50
Freeze Frame:
Voltage: 14.25 V
DU
Temperature: 27.0°C
RPM: 1498 /min
Speed: 50.0 km/h
Speed: 50.0 km/h
Count: 3
My error started when the stock battery started to go bye bye, but my new battery rests at 12.65 volts, versus the stock that was resting at 12 volts prior to its replacement.
XGC75
I'm in controls. 9 times out of 10 communication issues are down to the harness. 8 times out of 10 the connector needs to be unplugged and plugged back in.
Sent from my SAMSUNG-SM-G920A using Tapatalk
kern417
yeah i did a wire tuck and have gone through several of them. but for example, i had to add a ground to my passenger side harness under the headlight to get my foglights working. so if there is a specific ground needed to get the steering angle sensor working, i'd love to just splice in another lower gauge wire.
ChrisB1
Meh. Mine did it again this morning. I'm dreading bringing it back to the dealership only to have them tell me that nothing is wrong, yet again.
I guess it is time to start looking for a different car.
EDIT: A lovely pic from this morning...
