Have you looked on vwvortex? I don't know anyone that has done this...saw like one thread about it a long time ago. I would only replace the one harness if you need to. Are you having throttle issues?
Yes major issues followed the TSBs and its still throwing codes.
I did this.
You're completely replacing the plug on the wiring harness that connects to the throttle body. So every wire that goes into the old plug needs to be cut and attached to the new plug. If you buy the yellow VW/Audi repair wires I believe there will be a terminal which "clicks" into the new plug on each end of the wire, so you only need to buy three wires and essentially cut them in two for a total of six wires.
