VCDS, direct acceleration - throttle response - is this possible in mk6 (2.0 TSI)?
apache
2014 GTI, DSG
I'm trying to make the VCDS change to change the behavior of the throttle, but the "switch driving profile" option doesn't appear to exist.
The instructions I have are:
" go to the modules menu, click on Steering Assist (42) -> Click on Security Access -> Enter or select code 19249 -> Click on Adaptation -> Click on Driving profile swtchover -> click on "incremental controlled over time" and select "direct controlled over" and hit Ok. At the bottom of the screen press and hold the green checkmark until it says that the change has been saved "
Is this something that only exists on mk7 (not mk6)?
Thanks in advance.
