There's no reason to suspect that it won't fit. It looks like a standard double din, but there's very little info given about it, which is suspicious from such a legitimate company. You will need a dash kit though, something like this:
https://www.crutchfield.com/p_142VW2317A/Scosche-VW2317AB-Dash-Kit-Black.html
You'll also need something to retain steering wheel controls, if that's important to you. You can find that on Crutchfield as well.
I would highly recommend that you leave the rear speakers as is (unless they are broken) and spend as much money as you can on the front speakers. A decent set of components up front will may a significantly bigger difference than cheap coax speakers in all 4 doors.
Thanks bro. Appreciate all the info. My back door speakers still play quite well. My front door speakers are on the edge. So im changing them to JBL CS7”s. These mids look decent enough. For the radio, im just going to save until i have enough to buy a proper android device, a perfect fit. Including the steering control option ofcoz.
