I'm considering a water/ meth injection kit for my gti...
what is the best ratio to run? what are the benefits of running more water or more methanol? thanks
w/m vendors recc 50/50, i run 60 alcohol and 40 water b/c I'm set up for charge air cooling right now. higher % of methanol evaporates faster therefore cools faster. The octane boost comes mainly from the water, WWII planes used straight, plain water injection.
All you're doing when raising octane is being able to put that gas under higher pressure and heat with out it spontaneously igniting on its own (knock/pre-detonation)before the proper time in the stroke cycle. That can cause allot of damage.
