sauceman101
Finally at 129k first water pump began leaking, have everything out and ready to put back together, new water pump is BG revision.
My original 2010 water pump doesn't have a two pin (assuming temp) sensor on the inlet elbow (thermostat). Pretty certain as it's a sensor it doesn't actuate the thermostat, rather just monitor temp at an additional position. The BG water pump revision is for the CBFA, so I believe I received the correct pump from ECS. Considered swapping the old thermostat onto the new water pump but the internals are a bit different, going to install the new BG revision as is with nothing to plug into this sensor. I assume as it I believe it's just sensor not currently coded into the car I should be fine, anyone have any experience or knowledge about this? Can add photos this evening. Looked online and at installation guides and couldn't find anything at all pertaining to that plug. Any help would be greatly appreciated!
