BosnianBreakfast
I bought a second hand K04 and it is missing a turbo inlet pipe. Googling "K04 turbo inlet pipe" results in a bunch of products but none look like the pipe in the picture below (IE K04):
Is that silicon hose the outlet pipe or inlet pipe? It doesn't look like any TOP I have ever seen for K03/K04.Do you mean the OUTLET hose?
The Neuspeed TOP also looks drastically different to this as well.This is what you want. Or something like it. Idk what K04 kit you got and if the CTS one will work with other kits. They don't seem as readily available as the rest of the charged piping piecies. Maybe try contacting the company who made your kit.
https://www.ctsturbo.com/product/cts-k04-turbo-outlet-silicon/
Ah ok so that silicone hose is just called the "turbo outlet" and it connects to the actual TOP. That explains everything thanks!That's because they are two different parts. That Neuspeed TOP is what goes AFTER the silicone 90 degree pipe also it's not required that Neuspeed part only replaces the factory pancake pipe.
I have CTS K04 and didn't like the outlet elbow it came with. This is because the diverter valve relocation outlet is still present but they give you a plug since its not used. You can purchase a straight silicone 90 degree elbow separately from APR. Just call them. I think mine was around $50.
