Which ignition coils should I get
KarolisZiukas
Hey guys,
Really quick question. I'm getting misfire error codes occasionally and idle is pretty rough, so I've decided to change my ignition coils to see if that helps.
It would be great, that you could recommend coils that you are running and have no regrets getting them, because there are a lot of to choose from.
Thanks in advance!
P.s. shipping from Europe would be great :D
BudgetPhoenix
Only OEM. The Red or Black ones. Also are you getting misfire in all cylinders? Or just one? If its only one cylinder you can swap coilpacks to see if the misfire jumps cylinder, also check your spark plugs. You could also have a vac leak etc...
