MFactory
GolfMkV Sponsor
Hey Guys,
now that the initial test sets from Round 1 have shipped out to the designated testers, we would like to start an open-list for Round 2 of testing.
although the feature list below is 100% confirmed, we may make some design changes (for the better) based upon the feedback we receive from the Round 1 testers. However, now that we have the majority of the development process complete, we can finalise pricing, fitments and options:
MSRP - $1499.95
Round 2 Test Price (40% Discount) - $899.97
Deposit Required to be added to the production list - $500
Remainder (inc. any optional extras) due before shipment
ETA - July 2016 (this should allow us ample time to implement any design changes)
Fitments
Golf mk5 GTi/R32/Rabbit
Golf mk6 GTi/R
Options:
Inverted Dampers - $100/corner
Spherical Lower Mounts - $50/corner
Sports Spring Rates - ~50% stiffer than stock (balanced to oem F/R ratio. See feature list below for explanation)
Race/Drag Spring Rates - ~100% stiffer than stock (balanced to oem F/R ratio. See feature list below for explanation)
Custom Spring Rates (even rates, 4K-16K/224lb-896lb) - $50/corner, as we have to re-valve the dampers to match (we will not be held liable for upsetting the oem F/R ratio)
Helper Springs - TBD
Shipping (via UPS Ground. Have to wait for our monthly container, so around 3-4 weeks additional) - FREE
Shipping (via UPS Express as soon they are ready, so around 2-3 days) - $150
Softest Setting
Hardest Setting
YCW Reference Series Coilovers
- Spec'd for Superior Performance
- Priced for Affordability
- Over-Engineered for Comfort & Safety
FEATURES:
Forged 6061-T6 Hard Anodised Aluminium Front Upper Mounts
- Strong and Lightweight, our Forged Upper Mounts are Hard Anodised for superior Corrosion Resistance
Forged 6061-T6 Hard Anodised Aluminium Rear Upper Mounts (Where Applicable)
High-Tensile Carbon Steel Front Camber & Caster Plate with Anti-Slip Coating (MacPherson)
- CNC-Machined High-Tensile Carbon Steel supports more load than lesser-quality mounts
- Camber Angles can be adjusted precisely to your driving needs
- Caster Angles can also be fine tuned (MacPherson)
Oversized PTFE-Lined Japanese Spherical Upper Mount Bushing
- Increases shock articulation and prevents coil-bowing
- Higher load rating for increased durability
- Minimises knocking noise associated with lesser-quality bearings
Forged 6061-T6 Hard Anodised Aluminium Upper Spring Perch with Sealed Japanese Radial Bearing
- Strong and Lightweight, our Forged Upper Spring Perches are Hard Anodised for superior Corrosion Resistance
- High Quality Sealed Japanese Radial Bearing removes rotational stress from the upper mount and is sealed from the elements
62mm ID Cold-Wound Japanese SAE 9254V Chrome-Silicon-Vanadium Steel Linear Springs
- Custom-made for us in Japan from the highest quality Japanese-grade spring steel, using proprietary manufacturing processes
- Not all springs are manufactured the same. Lesser-quality, Taiwanese-manufactured springs offer inferior performance and durability
- Although more expensive, we believe the increase in performance more than offsets the marginal increase in manufacturing costs
OEM-Balanced Spring Rates
- The majority of budget coilovers currently on the market offer default spring rates that deviate from the oem-balanced spring rates
- By not accounting for Motion Ratio Calculations and just replicating race-car setups, this results in a very unbalanced and uncomfortable ride on a Street Car
- All Reference Series Coilovers are supplied with oem-balanced spring rates, offering you increased performance without sacrificing ride comfort
62mm ID Cold-Wound Japanese SAE 9254 Chrome-Silicon Steel Helper Springs (Application Dependent)
- Optional Helper Springs can be used to increase droop travel
52mm OD Cold-Drawn Japanese SAE 1020 Seamless Carbon Steel Shock Body
- Offers superior physical properties and strength-to-weight ratio over lesser manufacturing processes
Black-Zinc Plated Fully-Threaded Shock Body with 250hrs of Salt-Spray Testing
- Offers superior corrosion-resistance
14mm OD or 20mm OD (MacPherson) Forged SAE 4140 Chromoly Steel Piston Rod
- Monotube shocks, although offering increased performance over Twintube shocks, have an inherent weakness; a load-bearing Piston Rod
- Although Inverted Monotube Shocks are touted as the solution, these come with their own set of problems, not least the substantially increased cost of manufacture (Optional: $100/corner)
- Our over-engineered solution to the problem, with only a marginal increase in manufacturing costs, is our proprietary Chromoly Steel Piston Rod
- Offering a substantial increase in tensile strength over lesser-quality rods, not only does this keep costs down, it significantly increases product safety
Oversized Piston Rod Guide
- A common issue with the majority of budget coilovers currently on the market is performance-sapping deflection and shaft-play, even after only limited usage
- Through the use of our proprietary Piston Rod Guide, this minimises deflection and shaft-play, allowing you to reap the performance benefits for a longer period of time
7-Level Compression/Rebound Adjustment
- Our Reference Series Coilovers allow 7 levels of Compression/Rebound Adjustments, allowing you to fine-tune your vehicle comfort and handling
- Unlike the majority of budget coilovers currently on the market, with their 30+ Level Adjustments, you can physically feel the difference between each adjustment
- In this particular case, more is not better; it's simply an inconvenience and setup-nightmare
10cm/15cm/20cm Length Adjustment Extenders (Optional)
- Designed for vehicle applications with limited access to their upper strut mounts
44mm OD Forged 7075-T6 Hard Anodised Aluminium Digressive-Blow-Off DBO Piston™
- Over-engineered for superior strength, with anti-stiction and anti-friction properties
- At lower shock speeds (Cornering), our DBO Piston™ maintains a higher damping force, offering increased responsiveness and stability
- At higher shock speeds (Bumps), our DBO Piston™ maintains a lower damping force, offering increased comfort and control
Performance Synthetic Damper Oil with High Viscosity Index and Proprietary Additives
- A proprietary formula providing consistent damping over a wide temperature range and superior anti-stiction/anti-friction properties
Viton Performance O-Rings
- Upgraded O-Rings offering better performance and durability than lesser-quality Rubber O-Rings
Forged 6061-T6 Hard Anodised Lower Spring Perch Locking Collar
- Strong and Lightweight, our Forged Locking Collars are Hard Anodised for superior Corrosion Resistance
- 1pc Locking Collars, providing secure and hassle-free adjustments
Fully-Threaded Forged 6061-T6 Hard Anodised or High-Tensile Carbon Steel Lower Mount
- Threaded Lower Mounts allows us to use a longer shock body for increased performance
- Shock Stroke is unaffected by Ride Height changes
- Allows an increased Height Adjustment range
PTFE-Lined Japanese Spherical Lower Mount Bushing (Eyelet Type. Optional)
- Increases shock articulation and prevents deflection
Silicone Lower Mount End Caps (MacPherson)
- High Quality Weather-Proof End Caps for MacPherson lower mounts, preventing water and dirt from entering the the lower shock body
Weather-proof Neoprene Shock Covers
- High Quality Weather-Proof Shock Covers, preventing water and dirt from clogging up the shock assembly
Fully Rebuildable
- Our Reference Series Coilovers are fully rebuildable, with spare parts always in stock and available for purchase
Limited Lifetime Warranty on Hard Parts
- Warrantied against Manufacturers Defects
- Non-Transferable. Registration and Proof-of-Purchase Required
- Hard Parts include: Upper/Lower Mounts, Spring Perches, Locking Collars, Shock Body and Piston Rod
Limited 1 Year Warranty on Wear Parts
- Wear Parts include: Bearings, Springs, Seals and Shock Internals
Local Service Facilities
- North America: San Dimas, USA. Warranty Claims and Rebuild Services and Revalving Services available
- Europe: Leyland, United Kingdom. Warranty Claims, Rebuild Services and Revalving Services available
If you are interested in joining Round 2 of testing, or require more information, please PM me
MSRP - $1499.95
Fitments
Golf mk6 GTi/R
Options:
Softest Setting
Hardest Setting
FEATURES:
Fully Rebuildable
