Old 05-17-2017, 05:03 PM   #197
mojoooo0
Drives: gti mk6
Disconnecting the bluetooth module under the seat is super easy. Tab comes off easy.
mojoooo0 is offline   Reply With Quote
Old 05-17-2017, 07:54 PM   #198
1ashchuckton
FIA GT Newbie
1ashchuckton's Avatar
Drives: 2013 GTI CSG-DSG
Thank you for the help folks.
Next question who has installed a back up camera in conjunction with this radio? What kind did you use & how did you hook it up. I'm pretty confused about that aspect of this radio. I do believe I'm going to pull the trigger on the radio quite soon.
Old 05-17-2017, 08:22 PM   #199
mr wrong
Drives: 2017 Golf Alltrack
Originally Posted by Mr_Dog View Post
I am not sure about Android, but with my iPhone I am able to browse my Music & Podcast on the unit itself.
It is supported on Android, however I believe the Pixel's AVRCP bluetooth profile is not the latest which could be why.
Do you know what Android phones support this? It might be worth dumping my Pixel to gain this functionality..
2017 Golf Alltrack - JB4 -
mr wrong is offline   Reply With Quote
Old 05-18-2017, 07:35 AM   #200
LaRayes
LaRayes's Avatar
Drives: 2011 MK6 GTI APR K04 DSG
Originally Posted by iSuckAtThis View Post
For the OEM camera to work you'll need this adapter:
https://m.aliexpress.com/s/item/32383590304.html
And this cable: (some sellers include this cable with the HU)
https://m.aliexpress.com/s/item/2021946886.html
thanks for all the help guys. i went ahead and bought it off ebay and the link is below!
http://www.ebay.com/itm/VW-6-5-MIB-R...8AAOSww3tY6Qvk
LaRayes is offline   Reply With Quote
Old 05-18-2017, 04:04 PM   #201
jontalk
Oval Newbie
Drives: 2010 VW Golf, manual, coupe
After seeing so many posts saying this unit sounds much better than the RCD 510, I want to get one for my 2010 base Golf. What size torx wrench is needed to remove the old head unit? And when plugging my Galaxy S3 into the USB port to use Google Maps will the map graphic show on the screen? Sorry but this is all new to me Thanks
jontalk is offline   Reply With Quote
Old 05-18-2017, 11:22 PM   #202
saxgti
Drives:
Not too familiar with CarPlay - does this unit have the ability to play Spotify or YouTube (audio or video)? Thanks!
saxgti is offline   Reply With Quote
Old 05-19-2017, 10:55 AM   #203
TheCor
Drives: 2013 GTI Wolfsburg Edition
There are only certain apps that CarPlay supports - Spotify is one of them. I use Spotify nearly all the time on the unit, as well as podcasts. I assume Pandora is supported as well.
_______
H&R 24mm Rear Sway Bar | aFe Pro Dry S Drop-In Filter | DinanTRONICS Sport Performance Tuner | Black Forest Industries Dogbone Mount Insert | ECS Front Subframe Locking Collars
TheCor is offline   Reply With Quote
Old 05-19-2017, 11:29 AM   #204
Epic800
FIA World Rally Car Newbie
Epic800's Avatar
Drives: Bagged '10 GTI
It's T20 size to remove the radio.
Epic800 is offline   Reply With Quote
Old 05-19-2017, 02:22 PM   #205
jontalk
Oval Newbie
Thanks Epic..I assume you installed one also?
Old 05-22-2017, 05:05 AM   #206
Epic800
Epic800's Avatar
Installing it today. I just looked up a DIY on YouTube to remove the head unit.
Old 05-22-2017, 01:37 PM   #207
jontalk
Oval Newbie
There's a DIY on YouTube for removing the stock unit and installing the RCD330? Let me know how it goes. Also curious if you're an Apple or Android user. As an Android user I'm trying to find out if the Google maps image shows up on the screen when the phone is plugged into the USB port or if it's just contacts that you seek. Also don't know whether the unit has its own mic for hands free calling. Thanks
Old 05-22-2017, 09:58 PM   #208
Epic800
Epic800's Avatar
I viewed another DIY on removing the RCD 510 which I have in my vehicle. Below I am going to show a few steps that may help others when installing this headunit.
Tools Used:
Small Pry Tool
T20 Torx Screwdiver
Completion Time:
~20 Minutes
Installation Steps:
1. Remove faceplate from headunit using pry tool.
http://imgur.com/a/QpyeJ
2. Remove the 4 T20 screws as shown.
http://imgur.com/a/Bj5Uq
3. At this point, the headunit will pull directly out. Disconnect the CAN connector and antennas.
http://imgur.com/a/fOEAA
4. Included in the packaging is an antenna adapter that you will need to use. View picture to see how it connects.
http://imgur.com/a/Dq6r2
5. Plug in CAN connector and antenna. Then mount headunit and install faceplate.
http://imgur.com/a/luDRD
NOTES:
- From scanning this thread if you have Dynaudio you must unplug/plug your car battery to get everything to function.
Old 05-23-2017, 12:46 AM   #209
silentrob
Drives: 2012 Golf R
I tried searching for this the thread but didn't come up, but does the Climatronic settings show up when you adjust the temperature on the B version headunit?
silentrob is offline   Reply With Quote
Old 05-23-2017, 12:09 PM   #210
Frazam
Drives: MK6 GTI
Just installed it myself and I can only echo what everyone else has said - it's awesome.
No, it does not display.
Frazam is offline   Reply With Quote
