Stratified Flash Tunes Released for the MK6 GTI
uglybastard
Yes. More load on engine so revs increase to compensate
to expand on this... AC draws from the battery to run. battery reaches a certain low point, if you will, propmpting the computer to tell the engine to make more power for the battery via the alternator.
correct if wrong plz
lilonespaz
sounds riight to me. Plus dont forget the fans and spinning too when the AC is on so thats more power draw as well.
oldtype2
Got my Stratified tune installed today. This feels like a whole new car!
Hmm, I think new tires might be a good idea.
Thanks Alex! :thumbsup:
brobst
[emoji106] [emoji106]
Doritodan
Thanks Alex! [emoji106]
Wgats the process of getting the stratified tune that you went through or if someone from stratified would like to chime in. I read OP but a little more detail would help
Sent from my SM-G935P using Tapatalk
sterkrazzy
I got my cobb ap on a friday evening, but thanks to the time zone difference Strat was still open. I filled out their form they emailed me and about an hour later they had my tunes sent to me and I was ready to flash them.
They also send you info on things you should be looking for with your new tune and if you paid for data log refinement they'll send you info on how to data log.
It's a pretty easy process. They just email you the tune, you import the tune onto the cobb ap using your pc, and then you're ready to flash.
Alex@Stratified
Cheers, glad you like it!
If you don't have an AP, you can purchase one here and we include the tune.
http://www.stratifiedauto.com/index.php?main_page=product_info&cPath=209_219&products_id=677
Otherwise you can get the tunes from here:
http://www.stratifiedauto.com/index.php?main_page=index&cPath=209_219
Doritodan
sterkrazzy
Got my logs done!
thewalkingdad
For all you folks who have done your data logging for your tune adjustments:
What gear did you use on your slow build-up pull? I know I need to get two clean 3rd gear WOT pulls, but they also wanted a slower pull too and didn't say what gear to use.
