Old 03-07-2018, 01:19 AM   #1
edwardnese
Drives: 2011 GTI
How to test for bad PCV?
Hey guys i did some research and there seems to be multiple ways to test a bad PCV but i am still confused as to what signs to look for. So far i tested by:
  1. Start engine leave it idling, remove engine oil cap, engine starts sputtering and vibrating pretty hard.
Does this mean that my PCV is still good?
edwardnese is offline   Reply With Quote
Old 03-07-2018, 01:57 AM   #2
Wascally Wabbit
Rally Car Newbie
Yes I think that is normal. I believe if there is no change it is bad. I just replaced mine so I know it is good and my car does the same as yours when I remove the oil cap.
Old 03-07-2018, 02:03 AM   #3
snobrdrdan
Formula 2 Champion
snobrdrdan's Avatar
Drives: a VW
If higher mileage, just change it out for a new one since it is a maintenance item.
It's a simple swap and a pretty cheap part
2017 Passat VR6
Old 03-07-2018, 03:01 AM   #4
Boscogn
FIA GT Champion
Boscogn's Avatar
Drives: CSG 2013 GTI DSG 4DR
Hehe I thought u were trolling by telling them to change oil cap but I'm drinking and it just dawned on me ur talking about pcv
Wish List: Golf R InterCooler | Unitronic or IE CAI | P3 Air Vent Boost Gauge | 034 Motorsports RSB
NOTE: Please PM me if you are selling anything in my wishlist! Also check out my Build Thread!
Boscogn is offline   Reply With Quote
Old 03-07-2018, 04:33 AM   #5
Carlosfandango
FIA GT Champion
Carlosfandango's Avatar
Drives: 2010 MK6 GTI 6MT CSG
That DOES generally mean the PCV is good, however they can fail in several different ways and most do not directly produce any fault codes, but yours is probably good unless youíre getting other symptoms,
Take a look at this,
https://youtu.be/hQEciqR1ST8
Old 03-07-2018, 02:50 PM   #6
edwardnese
Drives: 2011 GTI
Thanks for that link, i am only suspecting PVC failure because i have a slow oil leak that happened recently about the size of 2 quarters that drips only after i have driven the car. Read online that a bad pcv can cause pressure buildup which would then blow our the rear main seal, but i havent gotten any CELs or fault codes.
Old 03-07-2018, 03:01 PM   #7
Carlosfandango
FIA GT Champion
I had a failed PCV last year that also took out the rear main! The only symptom was oil dripping from the join between the transmission and engine which started as a few drips but quickly got much worse, I had no CELís or fault codes, the PCV rarely logs any faults (directly) if at all, I also had to change the clutch as oil had got onto it as I left it a bit too long! I also changed the flywheel as it had to come off to do the seal so it wasnít a cheap repair for me, if it is your rear main be sure to use the latest revision and fit it correctly (not like the old revision) or it will leak again straight away!
Old 03-07-2018, 08:05 PM   #8
markus037
Touring Car Newbie
Drives: 2011 GTI 4dr DSG
i replaced mine at 55k for peace of mind
markus037 is offline   Reply With Quote
Old 03-08-2018, 12:24 AM   #9
edwardnese
Drives: 2011 GTI
How much was the cost for your jobs? and how long would u say u had the dripping oil issue for? so far its been half a week for me.
Old 03-08-2018, 12:30 AM   #10
BudgetPhoenix
Drives: 09 GLI
at a shop rear main seal alone will prob be around 1500. All labor due to removing transmission, bit more difficult if youre DSG.
Old 03-08-2018, 05:52 PM   #11
edwardnese
Drives: 2011 GTI
jesus thats quite a bit my car on kbb is only worth 6-7.5k and i already threw in 1800 in repairs this year for intake cleaning, and timing chain tensioner update.
In a dilemma now
Old 03-08-2018, 07:08 PM   #12
Carlosfandango
FIA GT Champion
In a dilemma now
£1189.08 GBP for me, (around $1650 US)
the clutch and flywheel were at cost price as the shop owed me a favour and the PCV was free due to the previous one only lasting a few months causing the rear main problem!
