Old 06-11-2019, 07:10 PM   #1
JerryTX
Build thread with GTXGen2 Content
Hi guys,
I am a long-time gearhead and it's time to document a little of this build, at least just because it's a little different. I bought a wrecked 2012 GTI with 90K miles in anticipation of my daughter driving it in a little over 18 months. I race and instruct and have been down this path already. The goal is to teach her to drive well and some of that will mean HPDE/track time.
Back to tech: the car had front end damage but no frame work was needed. I work with a great group of guys in Fort Worth at a shop for my other car stuff so they got to do the heavy lifting. Car is a 2 door, 6spd manual, no sunroof car. Before pic is below.
Since it needed a new intercooler anyway, I went with ATP front mount. Since the front end was blown apart the list of "while we are in there" grew to:
New OEM clutch, RMS, upgraded valve springs, walnut blasted head, new injectors, new water pump, and all new timing system components.
Interestingly the car was on a replaced crappy timing chain tensioner, but the original chain. The chain had plenty of stretch and needed to be replaced, so a new tensioner and guides went in as well.
I just got the car on the road, licensed/insured and made sure itís dead reliable. As soon as I drove it I realized the front wheel bearings were shot, and the horn was pathetic, so those got replaced. Now that itís bone stock and dead reliable, it's time to address the painfully slow portion! I want more power because I will drive it for the next bunch of months. I want it super predictable for my daughter and not over the top so it will stay open diff and relatively stock (and quiet). I am downgrading from 18Ē Detroit wheels to 17Ē Dallas wheels and going to a 245mm width tire for traction and no bent wheels.
The clutch is getting replaced now with the TT-RS pressure plate and TDI disk. Iím having Frank Mabo tune it with EuroDyne. And of course, the turbo: Garret GTX 2860R Gen II turbo. I ordered this to bolt up to the stock airbox and downpipe/exhaust. So if you are following this the net of the upgrades will be:
New Chrysler truck horn <- very important
H&R Springs
TTRS Pressure Plate/TDI Disk
GTX2860R G2 Turbo
Upgraded Valvesprings
ATP Front Mount Intercooler
Eurodyne custom tune.
17Ē Dallas wheels and 245mm width tires.
The car will need better brakes on track (it will only every go out on track pads and Motul brake fluid). I will be getting two tunes for the car: One to put it at about 230whp, and a max effort 93 octane tune for me. I donít expect (due to the downpipe or airbox) that the car will ever make more than 300whp, which would be about perfect IMO. It will always be traction limited. If my daughter decides she really likes the track time we can invest in more as needed but this should be a great start. Iím pretty sure Iím going to have to upgrade to a 3 bar MAP sensor for the tuning. Let me know your thoughts and impressions! Hope you enjoy. Pics of the turbo and the IC coming up as well..
JerryTX is offline   Reply With Quote
Old 06-11-2019, 07:57 PM   #2
brobst
brobst's Avatar
Drives: CSG mk6 6MT
I don't understand putting a gtx gen2 for under 300hp?
Sent from my SM-G960U using Tapatalk
Old 06-11-2019, 08:01 PM   #3
smanierre
smanierre's Avatar
Yea for 300 a k04 would be the perfect turbo. Although this could save you some money down the road if you want to expand
Sent from my Pixel 2 XL using Tapatalk
Edit: Also before the thread gets going too much, there is a dedicated section to build threads called member car journals so you may want to move it there
Old 06-11-2019, 08:15 PM   #4
JerryTX
Thanks for the suggestion on the build thread, I'll move it, sorry!
As far as turbo selection: it's definitely overbuilt there but underbuilt in other areas. All the K04's I've seen have alternative fueling, CAI, and exhaust to get big numbers. I won't be adding any of that. I wanted to make sure to hit 300ish and got a good deal on the turbo so went right to the GTX. The other thinking was it would be more topend and less low end power because open diff. Final thought there was if she gets into this and becomes a speed queen so be it, uncork it and but big brakes and an LSD in it.
Old 06-12-2019, 09:56 AM   #5
jay745
jay745's Avatar
I moved the thread.
Nice build so far. And de-tuning a big turbo is pretty smart for a track car. K04's run REALLY hot on a track. This would put the same power down (you don't really need much more and can get away without building the engine) and manage heat MUCH better. I have been considering getting a big turbo and selling my k04 for the same reasons. I don't really need any more power but the heat from the k04 is killer.
MK6 K04 GTI Build Thread
improvise. adapt. overcome
Old 06-12-2019, 10:37 AM   #6
JerryTX
I moved the thread.
Thanks for moving it and thank you for the feedback! I am hoping to do exactly as you stated: avoid the heat and avoid building the engine. I saw a picture on the MK7 forum comparing their IS38 to a K04 and the difference was huge, that kinda sold me on it. I've also pushed twin K04-like turbo's pretty hard on an F150 3.5L ecoboost and know there isn't much more left after 500rwhp on pump gas on 93 octane.
Old 06-12-2019, 10:55 AM   #7
smanierre
smanierre's Avatar
I'm curious to see what the stock airbox and exhaust can handle. Most people (including myself) upgrade those before a tune, let alone a turbo. Everyone just says they have to be done but I don't know of anyone that's tested it. Can't wait to see the results and if they aren't sufficient hopefully you get some warning before damage occurs.
Old 06-12-2019, 11:30 AM   #8
franco516
franco516's Avatar
Drives: gti
go with cobb accessport for easier map switching.
IG - @francotirador91
Old 06-12-2019, 11:44 AM   #9
GIACUser
GIACUser's Avatar
Drives: 2008 MKV EFR7163
Downpipes are cheap and not that difficult to change out. Stock downpipe will be a choke point. I would put a 3inch on there for your 18 months of fun and go for a little more aggressive tune. You can always swap back when you are done with it. No matter what you decide, I would put in an upgraded clutch rather than oem if this is going to be a track car for a while. Anyway looks like you have a plan, just thoughts based upon my past experiences.
| 2008 GTI | Turbozentrum EFR7163 | Aquamist 100% methanol | LSD | UNI custom DSG tune | Aquamist W/M | Brembo 18z brakes f/r | G-Loc pads R16-R10 f/r| Eibach R1 Coilovers | Neuspeed RSe11 18x8 Michelin Sport Cup2 | Recaro Speedseats |
Old 06-12-2019, 11:45 AM   #10
smanierre
smanierre's Avatar
Yea the oem clutch will slip in a tune so big turbo will roast it, and probably fast. Could probably get away with the rsr clutch kit which is oem-ish
Old 06-12-2019, 11:48 AM   #11
Allchokedup
Drives: 2011 ko4
Great build man! I have the same car just a year older..wish I had went big turbo!
I'm in the DFW as well, there are a few of us on here
2011 2 door, ko4,apr 2+,fmic,custom intake(bootleg) redtops, VMR810 19◊8.5
PS4s,some other stuff..
Allchokedup is offline   Reply With Quote
Old 06-12-2019, 12:02 PM   #12
JerryTX
I already bought the Eurodyne setup months ago so I can't undo that unfortunately. I think the switching will happen rarely anyway so it shouldn't be too big of an inconvenience.
Definitely may go this route. Puta 3" with a 200cell high flow cat, done it to plenty of cars and you are right, it's not that hard to do. I'm curious what the stock downpipe does though. Clutch: I'm getting the TTRS clutch installed now. Went with that because I'm hoping (and from what I've read) my daughter should be able to learn stick on it and not experience chatter. I don't want her to hate this car afterall
Thanks man, I'll bring it out to some events once it's done for sure!
Old 07-10-2019, 05:56 PM   #13
JerryTX
Out with the old..
Sent from my iPhone using Tapatalk Pro
Old 07-13-2019, 07:06 PM   #14
flight1us
Drives: Mk6 VW GTI
bump... nice build thread
flight1us is offline   Reply With Quote
big turbo mk6 gti
