OhioMK6
I've been protuning my K04 via Stratified and I've been having some fueling issues. Perhaps someone has experienced something similar and has found a solution or can point me in the right direction.
On full WOT pulls, usually in 4th gear for example, my car will fail to supply enough fuel some of the time. When this happens, actual rail pressure can be 300-500 PSI below requested. My injection times skyrocket, AFR's lean out, and my STFT rise to 1.25 (25%) My tune has been dialed back, but it still occurs, so it seems to now be a hardware issue. Has anyone experience this? If so, was it your HPFP, LPFP, injectors, or other? I've change the fuel filter and cleaned injectors to no avail.
I made 296WHP/320WTQ on a Mustang dyno, which shouldn't be the limits of stock fueling from what I've seen on here. I'd like to replace my weak link and get the car dialed in, but I'm not sure what to replace.
