Go Back   VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com > Technical Topics > TDI / GTD discussions
Old 06-12-2018, 03:10 PM   #1
TI KUFF
Newbie
Drives: GTD
Smile *SOLVED* GTD blows white smoke occasionally
I have a 2011 GTD which is DSG on 120k miles.
Since I've had it (11 months), it's been blowing white smoke every now & then.
It drives perfectly fine, no limp mode, misfire, stalling and etc pulls really well in all gears.
At first I thought it may be the headgasket or even the turbo, but after doing abit of research it doesn't have any of the symptoms that a blown headgasket or turbo would have.
It smokes maybe about once a week, it happens to smoke more after I've driven it hard.
Sometimes while the car is blowing smoke, the DPF light comes on for a few hours and then goes away.
Sometimes I can smell something chemically while the car is smoking, I don't know what it is but it does smell.
I got the car scanned for any faults and it found 2 faults:
Oxygen (lambda) sensor B1 S1 signal too high (Rich)
Throttle position sensor (G69) Implausible signal
Anybody have any idea whats causing the white smoke? Is it a faulty sensor that may need replacing?
Quite embarrassing when it does smoke lol
TI KUFF is offline   Reply With Quote
Old 07-19-2018, 05:57 PM   #2
muratferati
Newbie
Drives: Golf MK6 TDI 2010
My TDI was doing that ocassionally. Than i remapped it and got rid of DPF. 150k kms no problem no smoke at all.
Sent from my SM-G930F using Tapatalk
muratferati is offline   Reply With Quote
Old 02-27-2019, 12:43 PM   #3
TI KUFF
Newbie
Drives: GTD
*UPDATE
I have fixed the problem. DPF light was caused by a faulty lambda sensor, new lambda sensor fitted in 5 months ago and DPF light never to be seen again.
For the white smoke, it was a faulty throttle body. New throttle body white smoke and loss of coolant solved.
