Old 11-04-2015, 10:53 AM   #1
hasG6
Drives: Golf 6 1.6 TDI BlueMotion SE
Unhappy Help with the MDI cable please!
Hi Guys, I'm new to this forum, I have recently picked up a 2010 Golf 6 1.6 TDI BLUEMOTION SE, basically when I insert my iPhone cable into the USB end MDI it didn't use to recognise the device on the media screen, I then found an update online in which I updated the media system via Flash drive/ USB and now it charges the phone unlike before, but it still doesn't read the phone and comes up with something like 'device without compatibility' so anything I try play on the phone, nothing happens... When I connect through Bluetooth/ Aux it works fine... Did I download the wrong update? Please help, thanks in advance.
P.s. It's an IPHone 4s I'm using.
hasG6 is offline   Reply With Quote
Old 11-04-2015, 11:14 AM   #2
SELA_MK6GTI
SELA_MK6GTI's Avatar
The actual MDI plug for your phone might work better. I just got my 2013 GTI and I got the latest iPhone MDI cable and it works
Old 11-04-2015, 11:19 AM   #3
hasG6
A friend of mine had the same car and had, as you said, the actually MDI cable for the iPhone 4s and it worked perfectly with my phone, but I don't want to go out and purchase the exact plug as I change my phone quite frequently so that's why I was happy with the MDI with open female end USB, in which I thought I could just plug in any phone cable and it would recognise it and be able to play the music.
Old 11-04-2015, 11:24 AM   #4
SELA_MK6GTI
At least it charges it. You could just enable it with Bluetooth. Sounds more clear that way
Old 11-04-2015, 11:27 AM   #5
hasG6
Yes true but it would be nice not having to wait in the morning for it to connect via BT that's all, thanks for the reply mate.
Old 11-04-2015, 11:29 AM   #6
SELA_MK6GTI
Does your have a delay connecting via Bluetooth?
Old 11-04-2015, 11:29 AM   #7
SELA_MK6GTI
Not a problem
Old 11-04-2015, 11:37 AM   #8
hasG6
Yes it does sometimes, usually when you turn your Bluetooth on from your phone it should automatically connect to the cars media system, however I have to always physically click on the VW PHONE BT option on my phone then wait a while for the car to recognise it's being connected, the car will search for a while then eventually connect, takes maybe 30 seconds give or take.
Old 11-04-2015, 11:46 AM   #9
SELA_MK6GTI
Oh wow. Luckily I don't have that problem but sometimes it does act up and says it's connected but it doesn't play while it's been playing and let's say I get a phone call or something. Usually when I get phone calls but rare
Old 11-04-2015, 11:48 AM   #10
SELA_MK6GTI
That made no sense lol. So while its playing and I receive a phone call it'll stop playing obviously but after I end the phone call sometimes it'll remain "connected" but will act up and not play so I'll then have to disconnect it and just reconnect it
Old 11-04-2015, 11:53 AM   #11
hasG6
I have that exact same problem as well! Forgot to mention it, maybe it's just a common issue with the unit...
Old 11-04-2015, 12:13 PM   #12
SELA_MK6GTI
Yes possibly common issue. Doesn't happen to often but when it does it can cause a headache. Nothing an aftermarket head unit can't fix
iphone, mdi, media, tdi, usb
