NewGuy1
Hi Guys,
Just installed a stage 2 intake pipe to go along with my p-flo intake.
During install i did have some fitment issues that I was wondering if anyone knew how to resolve/ if it was normal.
First issue I had was with the coupler connected to turbo.
its pressed against the metal coolant pipes that run behind the engine.
In the area circled below, will get better picture later.
The second issue I had was compatibility with the p-flo.
Where the pipes couple with the MAF.
There is no room between the pipes and i had to add some washers at the mount to push the stage 2 pipe back a bit and allow room.
Third issue, which may have resulted from the washers I added was the attachment of the rear PCV tube.
I had to force this into place a fair bit, luckily this piece was recently replaced so i didn't have to worry about pipe snapping from old plastic.
However while doing this i did see some movement on the tube connector near the PCV end and im wondering if this may cause a leak.
At the moment I'm thinking the only way to resolve some of these issues is to slightly cut the stage two pipe to allow for more room for the p-flo intake.
This would allow me to remove the washers and possibly relieve strain on rear PCV tube.
Anyone have any less drastic ideas?
