uglybastard
went to a cold cars and coffee today. only mk6 there but lots of nice cars and a few other VWs showed up.
For whatever reason it won’t let me post picture but today.... I installed a set of Bilstein B14/16 coilovers, adjustable endlinks, GFB DV, and did some carbon cleaning. So much better of a ride!
Added auxbeam led for my low beams
Where did you put the ballast? These are awesome and plug and play? No splicing right? These might beat DeAuto’s H7RC!
I was going to say SQ5 but I think I prefer the look of the Atlas. And it looks like you can get a VR6! That should please a lot of people.
An Atlas is HUUUGE...physically on the outside, but has lots of room on the inside too
It does have 3.6 VR6, BUT that's an old engine....been around 12+ years now and it's just "okay" in the big Atlas
2.0T's will be rolling out soon....hopefully a tune on that should make it more potent
Dropped her off at the shop today for the hard shifting problem that developed the other day.
During my drive home from work, it suddenly became difficult to shift into gear. The lower the gear, the harder I'd have to push. Reverse was almost impossible. Higher gears were easier, but it still felt clunky.
I was hopeful all I had to do was readjust the shift cables, but there's only a problem when the engine's running- when it's off, it shifts just fine, so that can't be it. I don't think it's a bad slave cylinder, since there are no indications of a brake fluid leak. I read online where several others had the same symptoms, and most with the same diagnosis. Apparently, the pressure plate is a somewhat-common point of failure, where springs break, and it keeps the clutch disc from fully disengaging from the flywheel. My money's on that, but I guess we'll see when they call me back tomorrow.
Out of allllllll the common issues I've researched afflicting the Mk6, that's one I never saw, and that's the first one that really bit me
I know a couple owners and they're pretty happy with the Atlas. Only negative comment is the MPG. One is getting 13-14MPG city and another is getting 19MPG Highway. Thing is massive inside, much room.
Those are the same numbers I’m seeing in the Gti lol so that’s fine. It’s regular gas at least? Lol
Joined the LEDtails Gang tonite. Pics are from after i cleaned em down w rubbing compound. Bought from another member on here, lights are trash (depo, inner driverside light has melted led housing that i wasnt aware of until cleaning earlier tonite and seller didnt disclose this when i was there, but, idgaf), a tab was missing, two are fogged up and they certainly dont fit flush at all but for the price i got em, im satisfied.
