Do ya mind posting the version info screen?
here you go. Hardware and software are the same but android auto is enabled.
Do the steering wheel buttons still work with the RCD330?
So, is there a unit capable of running android auto that doesn’t have the fader bug? Or, so there a way to permanently fix that issue?
Looks super clean! I was thinking of doing something similar after seeing a post on a Russian site about it. Any issues running the extension? Does Carplay and Android Auto have an issues with it?Got an RCD330 Plus. Love it, works really well, especially for the price! However, I really hated the USB cable sticking out of the head unit, and it's a bit annoying there's no plug at the back for the USB switch harness.
Decided to solder in a USB extension, which just required pulling apart the unit and soldering to the back of the connector. I used the USB switch harness cable (be warned, the cable colours are the same as USB but do not match).
I then made some blanking plates, to hide the USB connector and card reader, out of self-adhesive blackboard vinyl. Came out looking really tidy, the matte finish blends in nicely.
Sent from my 2PS64 using Tapatalk
Mine arrived today. Wasn't wrapped up very well in the box and had no protector over the screen. The unit doesn't look new either. Can definitely tell it's been used. I gave it a good clean and it came up looking new. I still installed it though as I couldn't put up with the Eonon any longer.
This is the one I bought: https://www.ebay.com/itm/6-5-MIB-Ne...-w-Cable-6RD-035-187-B-Version-B/182657545674
I also had to trim the antenna adapter they supplied as it wouldn't have fit.
Overall I'm really impressed with it. I replaced my very slow Eonon GA6153F unit and this is lightning fast compared to that. Start up time is nearly instant. Audio quality has improved significantly over the Eonon and factory RCD310. I read about the audio issue after using Siri, but it was fine for me. FM/AM reception is really good, it's really clear compared to the Eonon. I had no problems tuning stations on either band. The eBay description said no RDS but it's working for me. I also like the fact that when you go from playing music from an external source back to the radio, the radio audio is muted.
Apple CarPlay works as expected, as does Bluetooth. Call quality & music playback is clearer through Apple CarPlay compared to Bluetooth, but the Bluetooth quality is still really good. And I have a feeling I will use Bluetooth more than Apple CarPlay, especially around town.
Next thing to do will be to scan for any errors using VCDS.
I really like the idea above of soldering in another USB connection. Might have to give it a go.
Can anyone comment on the battery drain rate if you don't have the correct CAN gateway revision? I think I'm starting to have issues with my battery but I'm also on the OEM one and it's just about 6 years old.
I have a 2012 GTI and I think it's rev H from the VAGCOM data below:
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 100911F1001007
Coding: 350002
Shop #: WSC 01357 011 00200
VCID: 356147F19C90E5E92C-8060
