Old 07-09-2018, 02:10 PM   #1
mossymemedogg
Drives: Golf R
Clunking Noise When Braking
Hey Everybody,
I bought a '12 R about a month ago and recently it started to make a clunking noise occasionally when braking, it usually happens under light braking. Its not loud, but its noticeable. Also I noticed a rattling noise that started at the same time the clunking did. The rattling sounds very tinny and I think its probably a heat shield rubbing somewhere near the DP, it happens always at the same revs: 1800-2000rpm. Anyone else have this problem?
A little info on the car:
6 spd
53k
APR Turbo back exhaust
APR stage 1+
APR hpfp
Thanks
mossymemedogg is offline   Reply With Quote
Old 07-13-2018, 05:36 PM   #2
bebersol
bebersol's Avatar
Originally Posted by mossymemedogg View Post
Hey Everybody,
6 spd
53k
APR stage 1+
APR hpfp
Thanks
The heat shield behind the turbo sometimes rattles, but you might check the entire exhaust to see if there is a close clearance somewhere.
The braking thunk is common on R's, mine did it in reverse. Tyrolsport makes a kit that takes the slack out of the caliper mounting hardware the thunk is then entirely eliminated.
Some R's also have a thunk under hard steering, that is from slack in the sub-frame. Tyrolsport also makes a dead-set kit to take care of that.
Bunch O'Stuff :-)
Old 07-25-2018, 08:36 AM   #3
mossymemedogg
Drives: Golf R
Thanks for the reply,
I just wanted to make sure there wasn't anything that was going to break, its not a healthy sounding noise. I will take a look at the Tyrolsport kit, was it a pain to install on your R?
Some things I have noticed while driving is that it really only does it when its hot outside (85+) so that could make sense if it has something to do with a rubber bushing being soft when its hot. Regardless of whether or not its causing any damage its something I would like to take care of.
Thanks
Old 08-04-2018, 05:32 PM   #4
Eric1285
Drives: 2009 GTI, 2013 Golf R
Does it happen when you reverse, brake, then go forward and brake?
I just had the HPA front brake kit installed on my R and noticed that every time I brake in reverse, I get a clunk from one side the first time I brake after going forwards. Did some research and it sounds like it's just the pad moving a bit inside the caliper. Supposedly a new spring clip will fix it, but it doesn't sound like anything to worry about.
Eric1285 is offline   Reply With Quote
Old 08-08-2018, 10:57 AM   #5
mossymemedogg
Drives: Golf R
Yes it happens in reverse and when I go forward, it makes a somewhat louder clunk in the hot weather, (where I live its been 85+ for the past month) in cooler weather it doesn't clunk as consistently.
If its not something that needs attention right away then I will probably wait until I do break pads and take a look. I purchased the car earlier this year and before my Golf I had a mk4 jetta and I was dealing with a nightmare situation of broken transmission mount bolts and clunking noises from underneath give me flashbacks to that shitshow.
Old 09-14-2018, 03:32 PM   #6
bebersol
bebersol's Avatar
The Tyrol sport brake deadset will likely take care of the brake clunk. Its not too hard to do, just buy a set of long nose C-clip pliers off Amazon to make it easier.
If your sub-frame has ever been dropped it will also likely make a clunking noise under hard turns, hard braking and hard starts. Tyrol also make a deadset kit for this, it's pretty easy to install. I think Hyde has a thread for the DIY. I did both of these to mine and no more clunks, and the suspension tightened up. I would do both deadsets before investing on other suspension stiffing items like sway bars and coilovers.
Bunch O'Stuff :-)
Old 09-27-2018, 08:27 PM   #7
HYDE16
HYDE16's Avatar
Drives: 2011 MK6
https://www.golfmk6.com/forums/showthread.php?t=48759
Facebook: Ryan Jacobs
Instagram:@becauseHYDE16
YouTube: HYDE16
