Big Turbo Discussion Thread
Status
Not open for further replies.
chrisisnapping
guys, did anyone here see the USP Jetta TSI that did a 10.9 run? Anyone with more info on the build?
"project madonna"
chrisisnapping
Well the car should hold some boost in between shifts so there's that right?
Do it. Break records, so someone goes gt35 and breaks your record, come on 650whp!
U-20T
you really think it would be that late? when would it start boosting then?
yes, a full size 3071r is roughly 3900rpm. The gtx will be about the same the bilet wheels are heavier than the cast ones but do flow more.
mine spools at about 3900-4100rpm with 58mm compressor and 58mm exducer.
kern417
yeah i guess i'm wondering when would you start to feel the boost build. and i'm assuming that's only at full throttle
Status
