lithiumbomb
I've had two two-day track events this year with my 2012 GTI. One at Road Atlanta and another at Carolina Motorsports Park. As expected I torched my original pads after my novice event at RA. As it's a 2012, the rear uses Bosch brakes while the front is the older ATE setup (aka, more pads available for front but not rear). Since I'm still much the novice I figured I'd stick with the same compound on all four corners, so tried HBC Yellowstuff pads.
They were toast after a weekend at CMP. Leading edges are crumbling and tailing edges are just glazed. The front calipers are now burgundy, which should subtract 5hp I guess. I'm trying to be modest, but at the speeds I'm doing I'm out-driving these brakes. I suppose I'll have to swing for track-only pads next and keep another set for the street.
So, recommendations for track pad setup on the otherwise stock brakes? And yes I know where this ultimately leads... (big brake kits, molesting a different car than my daily driver, etc)
Thanks!
Thanks!
