Just did my first log. We can only go up from here. Looking kinda raw.
http://www.datazap.me/u/brobst101/log-1495326132?log=0&data=1-5-9&zoom=1991-2094
I'm not too good at reading logs...caulkin is though...he should chime in.
My basic understanding is that I am meeting requested boost which is good, but the knock and timing are a little wonky. This was the ED base file and the turbo is not base, so that could be the issue. But I am waiting to hear back from Andy about what to do.
Yeah, this is the file he sent me for buying the Maestro.
Edit: where did you see 18? Did you convert a number?
Im gonna get the file tweaked. Yeah, needle dead on 18psi whole pull. Very strange imo. Such constant flow. I think there is a lot of headroom, but gotta fix the knock first
Yeah yeah. Charge and discharge pipes. Apr ic, uni dv relocation. Lil bit other stuff
Thats interesting. The IC did not seem to affect my stage 2 tune as significantly. I do not think my boost values changed.
Socal pnp set my k04 to 6psi cracking pressure which is factory spec, so it probably could be raised. I'll wait for an official response before tinkering just yet though. It could be the tune and the turbo just don't match right now.
I would most definitely work with the tune first, I'm just giving you my personal experience. Iirc Alex from stratified also had said the bigger ICs and higher psi numbers will need a stronger WG, but I'm holding 19, sometimes 20, so imo that seems pretty good.
I was not logging properly apparently. After logging again, it appears that I have a boost leak. Requesting 23psi and making 17psi.
http://datazap.me/u/brobst101/log-1495414728?log=1&data=1-4-5
Always good to check for leaks, but meeting requested doesn't always mean a boost leak...like I said, sometimes the WG cannot hold the pressure.
Fair enough. I am going to start with a pressure test, and then I will move onto the wastegate if everything is good pressure side.
