nik
Well, VW confirmed that they will not replace the intake manifold under warranty. VW Canada will not cover the warranty since I'm TD1, and Georgetown VW in Ontario, Canada (dealership that did the APR tune to my car) will not stand behind their work.
I've really had it with VW. Good driving cars and well designed, but just not worth the on-going reliability issues. Intake manifold failure, crank seal oil leak, timing chain tensioner, two wheel bearing failures, loose wastegate rod for turbocharger, sunroof switch problem, rear wiper fluid leak, paint peelng, all occurred under 180K kms. I don't think I'll make it over 200K kms without something (even more) major happening. But the worst part is that my local VW dealership service is horrible and they won't stand behind their product. It's time to move away from this marque.
The issue with us north of the border is we don't have the Magnusson Munroe act. Where the onus is on the dealer or manufacturers to prove your mod caused the fault. So unfortunately it's pay to play for us. Easier to deny warranty than spend money on an investigation.
Speaking from the OEM side, VW corp knows the car is now TD1. So they won't pay out to the dealer even if the dealer may have wanted to honour the work. Kind of puts them in a tight spot too as now the buck is on them. I'm not sure if the APR Georgetown relationship was approved at a higher level or if it was just at the dealer level and they got poo pooed for doing it by big brother.
