Old 09-11-2011, 08:01 PM   #1
GTIVI2011
Drives: 2011 black GTI
Dash lights after sub install???
Today I started installing my sub and amp into my 2011 gti. I did not finish so I just had wires running through the trim not really connected to anything. I had to take out the battery to run a wire from inside the car through the firewall. I then put back the battery and reconnected the battery. Other than that I did not touch anything else except the trim. When I started the car up it gave the a yellow steering wheel meaning problem with steering and then the little car with tread marks behind it. What could be the problem?
GTIVI2011 is offline   Reply With Quote
Old 09-11-2011, 08:39 PM   #2
(. )( .)'s Avatar
Drives: Slow
don't worry. my buddy disconnected my battery when he installed my intake and when we started the car, both those lights were on as well. drive a little bit and they should go away.
(. )( .) is offline   Reply With Quote
Old 09-11-2011, 08:44 PM   #3
ImAuthenticFTW
Drives: 2011 CSG DSG 2-door Autobahn
what he said
should go away after like 30-60 seonds of driving and you'll be fine. Might also have to set your power windows as well too. Hold the window buttons up at the auto point for a few seconds, then push them down and you should be set
ImAuthenticFTW is offline   Reply With Quote
amp, dash, lights, subs, warning
