Old 07-18-2015, 01:43 AM   #127
AustinM
Drives: 2013 (Mk vi) GTI
HELP!
I'm hoping this thread isn't too old to get some help with my 2013 GTI. I literally pulled my setup out of my old honda, bought new wires, and wired it almost exactly the same as it was when it was working in the Honda. Here's the setup:
PAC SOEM-T LOC
Alpine MRP-M500 Amp under drivers seat (remote to 12v cigarette lighter)
10" Alpine S Type in the trunk
The amp seems to work just fine, turning on and off with the accessory position of the car. Here's what's going wrong:
Although the amp turns on, I get zero sound out of my sub. I'll get a multi-meter to try to figure out where the problem is, but that's only the beginning.
Having my battery disconnected seems to have done something to the computer in my car. My traction control is off and I can no longer turn it on, my low tire light is on and the button in the glove box won't turn it off, and I get the "steering assist reduced" light on. Being new to VW this may be a dumb question, but does my car just need to acclimate after having the battery unplugged, or have I seriously messed something up? Any help would be greatly appreciated.
AustinM is offline   Reply With Quote
Old 07-18-2015, 06:39 AM   #128
sticksabuser
sticksabuser's Avatar
I've never heard of that happening. Maybe a short somewhere?
Sent from my Nexus 5 using Tapatalk
Old 07-18-2015, 10:34 AM   #129
AustinM
Possibly, The only two things I can think of are (a) it doesn't like having things plugged into the cigarette lighter or (b) I had to take the battery out to run my power wire and maybe having it out for that long reset the computer. Not sure.
Old 07-18-2015, 03:52 PM   #130
nikbrewer
Drives: 2008 gti
get your battery tested. VW's really act wierd when the battery is starting to get old. Less than optimal voltage makes crazy things happen
nikbrewer is offline   Reply With Quote
Old 07-18-2015, 09:39 PM   #131
AustinM
HELP!
Ok so the problems with my car are fixed, it didn't take long for the warning lights to turn off, but my windows were doing crazy things for like 20 minutes or so. Still no sound out of my sub though. I've tried a new LOC, I've changed out every cord in the system, I even took it to an audio shop and they said it was wired perfectly, they were as stumped as I was. Anyone have any ideas before I just give up and take it somewhere? I'd really like this to not be time and money wasted.
Old 07-19-2015, 11:01 AM   #132
nvturbo
nvturbo's Avatar
Did you test with another sub? Checked the wires inside the sub box?
....used to own a MK6 GTI
Old 07-19-2015, 01:45 PM   #133
AustinM
I've checked the wires everywhere, including inside the sub box. I haven't tested another sub, unfortunately I don't have another one nor do I know anyone that does. Knowing my luck I'm sure I've just got two bunk LOC's, but I'm afraid to send a third set of clips through my speaker wires without a guarantee of it working.
Old 07-21-2015, 03:17 PM   #134
xtant3150
Drives: 2012 GTI DSG 2door UGM
try hooking up another source to the amp. If you have a DVD player or something like that with RCA audio outputs, connect that to the amp (MAKE SURE TO TURN THE GAINS ALL THE WAY DOWN FIRST), ignore the video output. Put in a music CD and play it. Slowly turn up the gain on the amp and see if you get any output. That will at least tell you if it's the amp/sub and the wire between them.
Euro auto switch with sensor/Autodimming mirror with homelink/Depo led tails (no fog)/DeAutoKey interior, license plate, front & rear turn, fog, reverse, and city light led kits/DeAutoKey H7RC HID & H15 conversion kits/ECS Hatch Pop Kit/hacked BoldSport puddle leds/vag-com tweaks
xtant3150 is offline   Reply With Quote
Old 10-22-2015, 10:53 AM   #135
grantshane.sg
The add a fuse I have one, what one did you pull to use it? I don't seem to notice one changing in voltage with the key. Noob question lol just missing something.
Sent from my Galaxy S4 using Tapatalk
grantshane.sg is offline   Reply With Quote
Old 10-22-2015, 11:49 AM   #136
nvturbo
nvturbo's Avatar
Instead of doing that, use the rear trunk 12V socket for the remote turn-on power source. It will be the BLACK/RED (black with red stripe) wire. The brown wire is ground. It is easy to distinguish because these two wires are larger than the rest. You can actually connect to that wire at the wheel well, found in an exposed bundle of wires. You will have more room to work with at this location.
*** Make sure your key IS NOT in the ignition when you tap onto this wire. If you arch it against the car metal, you WILL blow a fuse. ****
amp, install, stereo, sub install, subwoofer
