Old 07-11-2013, 08:39 AM   #15
dcpppf
dcpppf's Avatar
Drives: 2012 VW GTI Autobahn
Originally Posted by SeanAP View Post
dcpppf: Great wright up! I am about 3/4 the way through my exact same build, I just found your post after a similar eye-opening experience when I realized I didnt have a rubber cover I could just pop off and stick the main power wire through. Could you post a couple pictures of your power wire going through the firewall?
One more question, do you think I will be ok running my 16.5 ft power wire along the passenger side?
My bad Sean just now seeing your post. Do you still need some pics?? I can snag some here at lunch time for you.
I think that 16.5' will be leaving less slack on the passenger side than the drivers side. I was able to gain a bit by running at an angle under the back seat. If you are coming down the passenger side it's all gonna be straight lines. Any special reason for wanting to run down the passenger side? I'd think it would be kind of a pain to get the power wire behind the glove box and all that garbage rather than just dropping down into the trim.
2012 CSG GTI MT Autobahn Timeline: 20% Tint // Clear Bra // APR Stage 1 Tune // DG Short Shifter // Verdict Shifter Bushings // 10" Uberstealth Sub Setup // Soundaktor Delete // BFI Dogbone Insert // APR 3" Downpipe & Tune // ECS Auto Hatch Pop // DEPO Black Cherry Tails // R8 Packs // Tinted Side Markers // Sachs SRE Clutch + PP // DV+ // Shortened Shifter Shaft // deAutokey LEDs // Polar FIS Adv// Euro Headlight Switch // Dash Cubby // Unitronic CAI (replaced Carbonio) // Unitronic Catback
dcpppf is offline   Reply With Quote
amp, nik, uberstealth, veedoubleme, woofer
