The Tire Rack
Old 09-17-2014, 10:56 AM   #1
Jeff43
Touring Car Champion
Drives: GTI 4 Door
!7s that fit over BBK w/out spacers
I put on a Brembo GT 330mm kit this past spring and now that winter is approaching I need to upgrade my winter set up to accommodate. I'd rather spend a little more on wheels vs. cheap wheels, spacers, longer lugs....So far the Neuspeed RSe05 is the only wheel i've found that will work without spacers.
Anyone know of other options?
Thanks,
Jeff
APR Stg 2|CTS DP-Milltek CB|Unitronic CAI|S3 IC|HPA SHS|HPA 75 mount|H&R 26/24|Tyrol Dead Set|SB Clutch Disk|S3 SS|DV+|.:R Tails|Brembo GT 330mm|RSe52s
Jeff43 is offline   Reply With Quote
Old 09-17-2014, 11:14 AM   #2
GunKata
Jawnie Sanders
GunKata's Avatar
Drives: '11 Pcar, '04 Honda CRV AWD Fury
TR Motorsports cleared my Stoptech ST40 328mm, but it was close. I think most of the OZ options on Tirerack that are 17x8 would probably clear, maybe?
Originally Posted by OmniGLH View Post
Everybody knows GunKata > *.*
No GunKata, no care.
Need remote help buying or selling a car?
Chicago Car Network
I can haz 350z racecar?
Gone: 2011 Audi A3 Quattro DSG K04
Also Gone: 2011 GTI Autobahn MT Stage 2 BBK Lots of Mods
GunKata is offline   Reply With Quote
Old 09-22-2014, 01:30 PM   #3
carsfeverguy
FIA GT Champion
Drives: 2010 Gti
Team dynamics
carsfeverguy is offline   Reply With Quote
Old 09-22-2014, 05:43 PM   #4
GTI_likeurmom
GolfMK6 Elite
GTI_likeurmom's Avatar
Drives: Veyron 16.4
yes the 45mm offset oz ultra's clear the cayenne calipers barely.
Originally Posted by GOBbluth View Post
I cut the tether off. When I get to the pump, I remove the cap and chuck it into the nearest bush, patch of trees, or some sort of wet lands. I pump gas. Then I spend anywhere from 5 to 165 minutes retrieving the cap. I screw it back on and drive away. I'm not letting it dangle against the paint and I don't know any better way.
GTI_likeurmom is offline   Reply With Quote
Old 09-22-2014, 06:30 PM   #5
jshay
Formula 5000 Champion
jshay's Avatar
Drives: GLI
My 17in EVO IX MR wheels cleared my 17z with plenty of space.
It's 17x8 et38
jshay is offline   Reply With Quote
Old 10-10-2014, 12:07 PM   #6
Jeff43
Drives: GTI 4 Door
Found these on the cheap...ECS rep wouldn't commit whether they would clear the brembos or not as he was not sure...
http://www.ecstuning.com/Volkswagen-...T35/ES2713034/
Thinking the flat spoke and 35mm offset should be enough....
Old 10-10-2014, 01:17 PM   #7
Shore GTI
Touring Car Newbie
Drives: 10 GTI/17 Golf SEL/16 F150XLT 5.0
BBS CO 18x8 Offset: 44mm
They fit over Stoptech ST40 328mm BBK.
No Centering Rings, spacers, or wheel bolts needed.
2Dr Autobahn CW Dynaudio APR S2/DSG S1
Carbonio/AWE DP & Milltek Race/SPM V2
BBS CO Summer/Detroit Winter/Stoptech BBK
UNIbrace UB XB/Hotchkis RSB/LED Tail Lights
DG & Bilstein B6..."Purrific together"
Shore GTI is offline   Reply With Quote
Old 10-10-2014, 02:30 PM   #8
Shore GTI
Touring Car Newbie
Oh! Just noticed that you are looking for 17" wheels.
Old 10-10-2014, 03:04 PM   #9
kern417
Formula 2 Driver
Drives: '09 Jetta
oz alleggerita is designed for bbk. alzor wheels are not. even though et35 is pretty aggressive fitmentwise.
do a burnout.
kern417 is offline   Reply With Quote
Old 10-10-2014, 03:54 PM   #10
apa11393
Formula 3000 Driver
Drives: GTX30 '12 GTI, '96 Miata
Enkei PF01 17x8 et50 clear my Stopteck st40 328mm BBK fine
apa11393 is offline   Reply With Quote
Old 12-29-2014, 07:13 PM   #11
jshay
jshay's Avatar
Drives: GLI
Originally Posted by carsfeverguy View Post
Team dynamics
Which model team dynamics? Thanks
