Old 02-06-2014, 04:03 PM   #183
trd420
trd420's Avatar
Drives: 2015 S3 Prestige+Performance Pack
Update the list with the UNI run of 11.6 @119
Now 2015 Audi S3 Prestige + Performance package, DTUK & K&N drop in. Running E-85 blend
Had 2011 MK6 GTI Unitronic Stage 2+ (K04)
Had 1989 MK2 GTI VR-6 Swap
trd420 is offline   Reply With Quote
Old 02-06-2014, 05:51 PM   #184
Thomas@GIAC
Thomas@GIAC's Avatar
Drives: Stage 3 B5 S4
The times on the list need to be at a certified track, which is why that run and a few of the K04 runs in Israel are not on there.
Thomas@GIAC is offline   Reply With Quote
Old 02-06-2014, 06:28 PM   #185
trd420
trd420's Avatar
O ok got it..
Old 03-11-2014, 11:23 AM   #186
MorePowah
Drives: 2013 vw GTI Wolfsburg
Thomas, on your site or AWE's the dyno that's on there shows an MKV, has the MKVI been any different in terms of performance? Also, you all seem to produce more hp, but a bit less torque than some other dynos I've seen... any particular reason this?
Also, it says for stage 2 intake and exhaust. Can you verify if the dyno runs were done on a full TBE or just a DP?
MorePowah is offline   Reply With Quote
Old 03-11-2014, 01:37 PM   #187
Fireball9298
Drives: 2010 GTI 6MT
CBE hardly make a difference...at least on our cars. As long as you have the dp, you are good. I felt zero difference when I added my CBE to my car with a dp already installed...but i knew that going in, i did it purely for the sound.
Fireball9298 is offline   Reply With Quote
Old 03-11-2014, 06:45 PM   #188
MorePowah
Thanks for that info, I figured the difference was little to none, as it is with a lot of turbo cars, but just thought i'd check.
Old 03-15-2014, 03:50 AM   #189
swagger76
Drives: 2012 CSG GTi mkvi autobahn
Official Golf MK6 2.0 TSI 1/4 Mile Thread
Trap speed was 107.-- Cut off in pic.
Mine on the right. Apr K04 100 oct DSG. Full weight. Bla bla bla. Sucked! No traction in first at all. When it got traction, I took off like a rocket. Track was terrible though. Couple stock GTI's ran mid 15's. My buddies stage 2 335i was slower than me. Drag radials would help tremendously albeit. So would more practice. Don't know how people are running low 12's with a K04?
swagger76 is offline   Reply With Quote
Old 03-15-2014, 12:04 PM   #190
mdhollis
mdhollis's Avatar
Drives: S3
^driver makes a big difference, especially with a fwd car. Like you said with a little more practice you will get that down into the 12s
mdhollis is offline   Reply With Quote
Old 03-15-2014, 01:43 PM   #191
Sspcivic31
Drives: APR Ko4'd 2010 CSG 4dr GTI
Your mph looks low. What are you shifting at? 2 things that have helped me the most are:
A. rev the shit out of it. i have a 6mt, but in order to get decent mph you have to shift as close to 7k as you can. never looked into the gear spread on a dsg car, but since the claimed hp peak is like 7k on the tune i think you would see the mph go up shifting higher.
my car will trap in the 106-108 range on 100 oct map shifting at stock redline
2. drive the car for at least 100 miles on the 100 oct map to let the car adapt. this has helped me get the mph up from 112-113 to 114-115.5 range.
i used to just put in 5 gallons and drive to the track about 40 miles away. now i fill up a week or two out from when i head out and it has helped eek the mph up.
Drag radials will help the e.t. i have seen about a .5 sec drop in the e.t. with them, but practicing getting out of the hole will help just as much. if you can get the 60ft down to the 2.0-2.1 range you would be tickling the 12's on street tires.
next time out try getting staged, rev the motor to 2700 rpm and when the last yellow comes on start letting off the brake and feeding in the throttle. slip the brakes like you would the clutch. once you are rolling a bit try going WOT.
if the car bogs really bad try stepping up in 200-300rpm increments until you find a good happy place.
Buy a VW, run some logs.
12.480 @ 114.09 V2.1
12.481 @ 114.91 V3.0
136.61mph Wannagofast Horseshoe Bay 1/2 mile
138.03mph Wannagofast Sulphur Springs 1/2 mile
Sspcivic31 is offline   Reply With Quote
Old 03-15-2014, 03:13 PM   #192
swagger76
Will do!! Thanks guys for the tips!! My first run was pathetic. Let the air out of the fronts to 22 psi. That really seemed to help to. I was in sport mode so I was shifting about 6500. I'll go manual mode next time and shift later. I know the car can get into the 12's easy. Just a matter of practice.
Old 03-15-2014, 06:44 PM   #193
recognized1
recognized1's Avatar
Drives: 2011 VW GTI
Maybe on a KO4 it's different but you should be shifting yourself and NOT let it go to 7k in sport mode. I would shift once you see the needle hit 6k because by the time you see that you actually be shifting around 6300-6500.
Definitely drive the car around for 15 minutes to let it adapt to 100 octane tune. No need to drive a 100 miles.
Work on your launch. Don't use launch control. Disengage that and rev around 2200.
recognized1 is offline   Reply With Quote
Old 03-15-2014, 08:06 PM   #194
swagger76
Will do!! Next track day in May. Will work on all the suggestions!!
Old 03-15-2014, 08:42 PM   #195
Sspcivic31
might be like always wearing the same socks to bat or what not, but for me the extra drive time on the 100 octane map does help.
Old 03-15-2014, 09:06 PM   #196
recognized1
Drives: 2011 VW GTI
Yeah that's overkill but if it makes you feel good then go for it.
