Old 06-07-2018, 08:25 PM   #1
iSpeed
High Coolant Temps
Sup fellas!
I recently installed a K04 kit in my 2011 GTI with a plethora of supporting mods. It runs great and strong but I'm noticing the running coolant temps jump to 220 or higher sometimes when I am in the city with the A/C on. The fan kicks in hard when it gets above 220(I'm reading the temps via the Torque app) and it will run for a solid 5-10 mins after I turn the car off.
I'm wondering if its common or should I be looking into a better radiator or is this a sign of a water pump starting to go?
Thanks!
iSpeed is offline   Reply With Quote
Old 06-07-2018, 09:53 PM   #2
BudgetPhoenix
Drives: 09 GLI
Whats the highest you've seen? 220 is fairly typical. Ive seen that on warm days especially in the city.
Old 06-08-2018, 12:33 AM   #3
iSpeed
227 is the highest I've seen it. It regularly gets to 224 when I'm hot roddin in the city. My brother has a Mk6 GLi with the same mods and his never gets above 210 so it has me wondering...
Old 06-08-2018, 02:27 AM   #4
MLue1
Flush your rad, add new coolant and bleed the air out. OR thermostat???
Old 06-08-2018, 09:39 AM   #5
mraaf
Drives: 2011 MK6 GTI
Different coolant mixture after k04 install
REVO 3
mraaf is offline   Reply With Quote
Old 06-08-2018, 01:53 PM   #6
MmmmmBoost
Drives: 2013 GTI MK6
Torque reads like 10-15 degrees higher than the actual temp, I use to run it till I got my Cobb AP and VCDS.
MmmmmBoost is offline   Reply With Quote
Old 06-08-2018, 02:10 PM   #7
BudgetPhoenix
Drives: 09 GLI
Interesting. I have Torque, OBDEleven and VCDS. Ill compare on my lunchbreak. I know theres multiple coolant temp measurements in VCDS, like radiator outlet, inlet etc. I wonder what Torque reads off of.
Old 06-08-2018, 07:13 PM   #8
Sspcivic31
Drives: APR Ko4'd 2010 CSG 4dr GTI
the stock thermostat doesn't fully open till some where at or above 220F.
Buy a VW, run some logs.
12.480 @ 114.09 V2.1
12.481 @ 114.91 V3.0
136.61mph Wannagofast Horseshoe Bay 1/2 mile
138.03mph Wannagofast Sulphur Springs 1/2 mile
Sspcivic31 is offline   Reply With Quote
Old 06-08-2018, 09:45 PM   #9
BudgetPhoenix
Drives: 09 GLI
I was comparing my measurements today. The G62 coolant temp sensor in obdeleven and the torque reading seemed to be the same. I saw temps go from 204-220 after car was fully warmed in mostly stop and go traffic on my commute home. 82F ambient temp. It liked to sit around 204 when cruising though.
Old 06-09-2018, 03:58 PM   #10
iSpeed
This is good news to hear guys!
When I did the K04 install I lost a lot of radiator fluid and replaced it with half a gallon of 50/50 G13.
I was looking at getting a performance radiator but I'll do the radiator flush first and see if that helps.
As a side note, I will say that when I installed the CTS intercooler I noticed the car gots hotter quicker. I'm wondering if the thicker IC doesn't allow as much air to flow through the radiator considering the radiator sits behind the IC.
Old 06-09-2018, 04:01 PM   #11
iSpeed
Is there an after-market thermostat that you know about that opens fully sooner?
Old 06-11-2018, 10:59 AM   #12
lilonespaz
lilonespaz's Avatar
Why though? 220 aint that bad.
I regularly sit at 210sih normal driving and sometimes 215-220 while in heavy traffic.
Old 06-14-2018, 12:10 PM   #13
thatspsychotic
thatspsychotic's Avatar
What intercooler are you running? Front-mounts (in front of everything, especially if the OEM sandwich mount IC is left in place) have been known to cause higher coolant temps due to the airflow obstruction that they are.
APR Stage 2 v2.4, Carbonio, Cast Downpipe | PTP Turbo Blanket | GFB DV+ | Unibrace UB | Tyrolsport Deadset | BFI Stage 1 Mounts | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18
Old 06-14-2018, 12:16 PM   #14
jay745
jay745's Avatar
Yep this has been my problem on the track. I'm switching to a sandwich mount IC this year and adding an oil cooler.
