Old 06-19-2018, 10:39 AM   #1
FishesDelicious
Drives: 2014 MK6
Possible blown turbo, have had APR stage 1 for about 75,000 miles.
Are VW dealers still stingy on warranties after a tune? CEL code is showing p0299 which could be a blown turbo or something related. Im hesitant on bringing it in at the dealer and considering bringing it back to the APR shop to get it flashed back to stock first. The problem is that the APR shop is 3 hours away and I'd be driving the car there :/. The turbo isn't spooling at all, no boost leaks.
FishesDelicious is offline   Reply With Quote
Old 06-19-2018, 10:49 AM   #2
Auwdee
Drives: Mk6 GTI
If i'm not mistaken you should be fine cause apr is dealer friendly but then again certain dealers are hesitant so the best thing to do is take it to the dealer, and of they turn down your warranty claim then contact apr and see if they can check your logs and etc. But youre only stage 1 so I dont see how that could happen by a tune.
Auwdee is offline   Reply With Quote
Old 06-19-2018, 10:52 AM   #3
FishesDelicious
Drives: 2014 MK6
Wouldn't forcing more air through the turbo void the warranty if damage happened to the turbo? I know these turbos go eventually, but I also know VW dealers were hit or miss if they play ball with tunes, regardless of APR or not. At least they were back when I had it done in 2014/2015.
I'll have to call the tuning shop I had it done at and see what they say.
Old 06-19-2018, 11:01 AM   #4
Gti For Me
Gti For Me's Avatar
Drives: 2011 GTI APR K04 V.3.1
have you check your diverter valve for torn diaphragm which cause's to throw a p0299 code
THE #1 BBK KIT WITH A GREAT PRICE AND THE ANSWER IS V-MAX V-MAXX V-MAXX..............GET IT TO YOUR THICK HEAD OR SHOW ME PROOF THEY ARE CRAP
Gti For Me is offline   Reply With Quote
Old 06-19-2018, 11:21 AM   #5
FishesDelicious
Drives: 2014 MK6
Nope, not yet. Wouldn't that cause a boost leak though? I can't hear anything leak under throttle.
Old 06-19-2018, 11:27 AM   #6
eldiablo
eldiablo's Avatar
Drives: Hebridean Dance interior
Aren't you way beyond the powertrain warranty terms anyway?
Pumping the air back into despair.
My Journal
eldiablo is offline   Reply With Quote
Old 06-19-2018, 11:29 AM   #7
FishesDelicious
Drives: 2014 MK6
I opted for the 100,000k extended warranty
Old 06-19-2018, 11:40 AM   #8
eldiablo
eldiablo's Avatar
That's good. Be straight up with the dealer and let them know that you can only have them fix under warranty, otherwise you'll have to take it elsewhere. My guess is that they will take the work.
My Journal
Old 06-19-2018, 11:42 AM   #9
Cadubya
“DUBYA” VP COUCH MOD
Cadubya's Avatar
P0299 is a boost leak. Check all your pipes and your diverter valve. A smoke test is the best way. If you don’t already have a rev D one replace it.
CLICK HERE FOR MY BUILD
Old 06-19-2018, 02:26 PM   #10
thatspsychotic
thatspsychotic's Avatar
I'm with the rest of you on the boost leak, diverter valve being the most obvious candidate since if it is totally failed, it will be impossible for the turbo to create boost. Also note that if it is an internal leak with the diverter valve, it won't necessarily show up in a smoke test.
I'd be shocked if you had a failed turbo with that trouble code and so few miles. For reference, I'm at 148k miles and have been stage 1 since 80k miles, so 68k miles tuned. From other posts on the forum, one guy had a turbo let go at over 200k miles and it was due to oil leaks, and it still made good boost despite leaking oil and smoking.
APR Stage 2 v2.4, Carbonio, Cast Downpipe | PTP Turbo Blanket | GFB DV+ | Unibrace UB | Tyrolsport Deadset | BFI Stage 1 Mounts | SuperPro Offset LCA Bushings | Enkei Raijin Gunmetal 18x8 et45 | Michelin PSS 245/35R18
Old 06-19-2018, 03:43 PM   #11
Ik1015
Drives: mk5 ug
I think that warranty was not directly from VW and 3rd party.
I will take GTI to dealer for diagnosis. If dealer finds something, they claim warranty company and will do repair after approval.
Ik1015 is offline   Reply With Quote
Old 06-19-2018, 04:25 PM   #12
BudgetPhoenix
Drives: 09 GLI
Can also be caused by a bad tune and a failed turbo.
Old 06-19-2018, 04:40 PM   #13
FishesDelicious
Drives: 2014 MK6
I've read it can be a bad turbo or DV or something else. Prior to CEL coming on it was running fine, no boost issues at all. After getting off work the turbo was immediately dead - no boost at all or leaks that I could hear.
I blew a turbo once in my old 1g DSM and it had a super loud whine and boost leak whenever it tried to spool up. I don't hear anything with my GTI. I think I'll bring it in to the dealer and have them diagnose and if whatever it is isn't covered under warranty due to a stage 1 tune I'll bring it back to the APR shop to set it back to stock then bring it to a difference place.
Old 06-19-2018, 05:25 PM   #14
thatspsychotic
Some kind if failure regarding the wastegate could do it... but you'd see a little bit of boost at high RPM, more than 0 psi.
Diverter valve stuck open would 100% explain the CEL and no boost, but should probably make a wooshing sound. Dealer (if they don't flat out refuse to work on the car due to tune) will find the issue for sure.
