Old 05-09-2018, 05:15 AM   #1
2020hs
Drives: Sparkle in my eye
Installing the Sony XAV-AX5000, USB to center console?
Hi,
Looking at getting one of these units then bringing the 2 usb slots through to the center console, has anyone had experience with doing this? Seems like a more convenient location. Does anyone know what sort of adapter I would need to continue utilising steering wheel functions or will someone from a local parts store be able to help?
Ta
2020hs is offline   Reply With Quote
Old 05-09-2018, 07:33 PM   #2
realcyberbob
realcyberbob's Avatar
This would probably be your best bet to bring the USB connections near the center console: https://www.doubleapex.co/collection...dual-usb-ports
Old 05-15-2018, 09:54 PM   #3
Indicted
Drives: 2011 MK6 GTI
This is what I ended up doing for my XAV-AX100 as I didn't want USB cord laying around inside of my car.
To retain steering wheel control, you need something like this
https://www.crutchfield.com/p_541RP4...e.html?tp=3486
I am able to use following functions: skip, previous and volume control.
After switching the coding In VAGCOM, I can use voice control button as mute(significantly drops the volume).
Sent from my SM-N950U using Tapatalk
Indicted is offline   Reply With Quote
Old 08-07-2018, 02:19 PM   #4
otis_bartleh
otis_bartleh's Avatar
Drives: 2011 Golf TDI 2dr 6spd
I did something similar when I installed my XAV-AX200 which I use Android Auto on. I used the Double Apex USB pass-through port, but put it in the center console where the stock AUX plug is, since that plug is useless to me. Then I have a 1ft USB cable going from there to my phone, which I keep under the ebrake. It is the perfect length to fit nicely and not have a bunch of cable all over, and keep my phone secure. I had to trim some of the backside of the USB port, and put it sideways for the best fit without modifying the console itself. I also used some paint thinner to remove the "USB" label from the cover so it doesn't look odd. Came out pretty awesome I think.
I used the same item linked above to retain steering wheel control.
A quick charge USB port is going in the far right switch location in front of the shifter for passengers or if I need some juice quick...
Also, for the stereo's microphone, I modified the ashtray I bought to replace the useless storage compartment, and put the microphone in there, coming up through it. It stays out of sight, and works nicely...
-Adam
2011 Golf TDI 2-Door 6-Speed - Black
otis_bartleh is offline   Reply With Quote
