HandicappedGTI
so im redoing my trunk setup as i bought the car bagged and whoever bagged it just threw everything under the floor, i want to place sound deadning to lower the sound, but does anyone know how many sq ft i need?
I'm not sure anyone will be able to answer that for you. It'd be best if you measured it yourself Are you talking only about the small section that lifts up? Or the whole trunk false floor? How many layers of sound deadening do you intend on using? I'd say you'll need at the very least about 4ftx2ft so 8 sqft. But if you're not gonna measure it I'd get way more to ensure you're covering everything.so im redoing my trunk setup as i bought the car bagged and whoever bagged it just threw everything under the floor, i want to place sound deadning to lower the sound, but does anyone know how many sq ft i need?
Sent from my SM-G935V using Tapatalk
that gives me a good idea, and yeah the whole false floor, like 80 percent of my road noise is from the trunk area and im going crazy lol
If you're trying to kill road/tire noise, your typical dynamat type deadener (foil, and butly) will do next to nothing. You need something like MLV (mass loaded vinyl) to combat the low frequency drone of road/tire noise. Dynamat, and similar products are great for stopping panel vibrations/resonance, but the metal in your trunk isn't particularly prone to this because of the bends in the sheet metal.
x2 on the MLV - i used some of the dynamat type of stuff and did my entire hatcharea to help kill road noise, it really didn't help much at all. just helped keep panels from vibrating as much, in which case i would have been better off just using some thick foam tape where the panels were hitting the metal in the first place
