Full scan if needed
VCDS Version: Release 15.7.3 (x64) Running on Windows 7 x64
Data version: 20151216
www.Ross-Tech.com
Monday,25,January,2016,16:03:16:54182
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ0CW291088 * Mileage: 75270km-46770miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CBF) * * * Labels: 06J-907-115-CBF.clb
* *Part No SW: 1K0 907 115 AT * *HW: 1K0 907 115 AK
* *Component: 2.0l R4/4V TFSI * * 0040 *
* *Revision: E3H26--- * *Serial number: * * * * * * **
* *Coding: 040301081C070160
* *Shop #: WSC 26974 001 1048576
* *VCID: 78F5DAC40B00EDFE49-802C
No fault code found.
Readiness: 1110 1101
Address 02: Auto Trans * * * *Labels: 02E-927-770.lbl
* *Part No SW: 02E 300 057 R * *HW: 02E 927 770 AL
* *Component: GSG DSG AG6 * * 512 3115 *
* *Revision: 05551213 * *Serial number: 00001202281286
* *Coding: 0000020
* *Shop #: WSC 01357 011 00200
* *VCID: 2855CA849B20BD7E19-807C
Address 03: ABS Brakes (J104) * * * Labels: 1K0-907-379-60EC1F.clb
* *Part No SW: 1K0 907 379 BJ * *HW: 1K0 907 379 BJ
* *Component: ESP MK60EC1 * H31 0121 *
* *Revision: 00H31001 * *
* *Coding: 114B600C492B00FB880B06EC92210041B70800
* *VCID: 7BFFC5C8FA36C6E624-802E
1 Fault Found:
02214 - Tire Pressure Warning*
* * * * * * 002 - Lower Limit Exceeded - Intermittent
* * * * * * *Freeze Frame:
* * * * * * * * * * Fault Status: 00100010
* * * * * * * * * * Fault Priority: 2
* * * * * * * * * * Fault Frequency: 1
* * * * * * * * * * Reset counter: 147
* * * * * * * * * * Mileage: 75110 km
* * * * * * * * * * Time Indication: 0
* * * * * * * * * * Date: 2016.01.24
* * * * * * * * * * Time: 12:42:04
* * * * * * * * * * Count: 0
* * * * * * * * * * Count: 32768
* * * * * * * * * * Count: 4608
* * * * * * * * * * Count: 16401
* * * * * * * * * * Count: 51712
Address 08: Auto HVAC (J301) * * * Labels: 3C8-907-336.clb
* *Part No SW: 7N0 907 426 AN * *HW: 7N0 907 426 AN
* *Component: AC Manuell * *H19 0404 *
* *Revision: 00001018 * *
* *Coding: 0000001002
* *ASAM Dataset: EV_ACManueBHBVW36X A01010
* *ROD: EV_ACManueBHBVW36X_VW36.rod
* *VCID: 0005B2249BD0A53E71-8054
Address 09: Cent. Elect. (J519) * * * Labels: 1K0-937-08x-09.clb
* *Part No SW: 1K0 937 086 P * *HW: 1K0 937 086 P
* *Component: BCM PQ35 *M * 110 0651 *
* *Revision: 00110 AC * *
* *Coding: 6F180A3F90272AC4008800C17000056448010386434D8D60648020200040
* *VCID: 3D7B0BD0A4A208D65A-8068
* *Subsystem 1 - Part No: 5K1 955 119 * Labels: 1KX-955-119.CLB
* *Component: Wischer 01031 *26 *0512*
* *Coding: 009795
1 Fault Found:
02394 - Parking Light Left Front (M1)*
* * * * * * 014 - Defective - Intermittent
* * * * * * * * * * Fault Status: 00101110
* * * * * * * * * * Fault Frequency: 24
* * * * * * * * * * Mileage: 74375 km
* * * * * * * * * * Date: 2016.01.15
* * * * * * * * * * Time: 11:02:01
* * * * * * * * * * * * Term 15 On
* * * * * * * * * * Voltage: 14.25 V
* * * * * * * * * * * * ON
* * * * * * * * * * * * Term 50 On
* * * * * * * * * * * * OFF
Address 15: Airbags (J234) * * * Labels: 5K0-959-655.clb
* *Part No SW: 5K0 959 655 H * *HW: 5K0 959 655 H
* *Component: AirbagVW10G * 013 0724 *
* *Serial number: 003GVRA1S03X *
* *Coding: 00003131
* *ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
* *ROD: EV_AirbaVW10SMEVW360_SE36.rod
* *VCID: 3F8771D8A6AE1AC648-806A
* *Seat occupied recognition:*
* *Subsystem 1 - Part No SW: 5K0 959 339 B * *HW: 5K0 959 339 B
* *Component: BF-Gewichtss. *006 0001*
* *Serial number: ---0000R--00003JBW00
* *Crash sensor for side airbag; driver side:*
* *Subsystem 2 - Part No SW: 5K0 959 354 * * HW: 5K0 959 354*
* *Component: S.Sens.Fahr.V *H01 ----*
* *Serial number: 3572MSME5073026CZZZS
* *Crash sensor for side airbag; front passenger side:*
* *Subsystem 3 - Part No SW: 5K0 959 354 * * HW: 5K0 959 354*
* *Component: S.Sens.Beif.V *H01 ----*
* *Serial number: 3582MSME6F2F346BZZZD
* *Crash sensor for side airbag; rear; driver side:*
* *Component: S.Sens.Fahr.H *--- ----*
* *Serial number: 3512QSME6C010E2DZZZ$
* *Crash sensor for side airbag; rear; passenger side:*
* *Component: S.Sens.Beif.H *--- ----*
* *Serial number: 3522QSME56126D11ZZZR
* *Crash sensor for front airbag; driver side:*
* *Component: F.Sens.Fahr *--- ----*
* *Serial number: 35527SME22046C2BZZZF
* *Crash sensor for front airbag; front passenger side:*
* *Component: F.Sens.Beif *--- ----*
* *Serial number: 35627SME7706692BZZZP
Address 16: Steering wheel (J527) * * * Labels: 5K0-953-569.clb
* *Part No SW: 5K0 953 507 AH * *HW: 5K0 953 549 B
* *Component: Lenks.Modul * 008 0080 *
* *Revision: -------- * *Serial number: *90422LC500056
* *Coding: 189A140000
* *ASAM Dataset: EV_SMLSNGKUDS A05001
* *ROD: EV_SMLSNGKUDS_SE36.rod
* *VCID: 76E9D4FCC9149B8E5B-8022
* *Multi Function Steering Wheel Control Module:*
* *Subsystem 1 - Part No SW: 5K0 959 542 * * HW: 5K0 959 542 * Labels: 3C8-959-537.CLB
* *Component: E221__MFL-TAS *H08 0010*
* *Serial number: 0016341 * * * * * **
* *Coding: 830000
Address 17: Instruments (J285) * * * Labels: 5K0-920-xxx-17.clb
* *Part No SW: 5K6 920 972 C * *HW: 5K6 920 972 C
* *Component: KOMBI * * * * H03 0607 *
* *Serial number: 00000000000000
* *Coding: 270F01
* *ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
* *ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
* *VCID: 366914FC8994DB8E9B-8062
Address 19: CAN Gateway (J533) * * * Labels: 7N0-907-530-V2.clb
* *Part No SW: 7N0 907 530 M * *HW: 1K0 907 951*
* *Component: J533 *Gateway H42 1623 *
* *Revision: * H42 * * * Serial number: 040312F2001302
* *Coding: 350002
* *VCID: 3A7100CCB58C3FEE7F-806E
Address 1C: Position Sensing * * * *Labels: 1Kx-919-xxx-1C.lbl
* *Part No SW: 5N0 919 879 * * HW: 5N0 919 879*
* *Component: Kompass * * * * 001 0001 *
* *Revision: 00001000 * *Serial number: 1225223RH76106
* *Coding: 0000002
* *VCID: 7EF9CCDC2924D3CE03-802A
Address 25: Immobilizer (J334) * * * Labels: 5K0-920-xxx-25.clb
* *Part No SW: 5K0 953 234 * * HW: 5K0 953 234*
* *Component: IMMO * * * * *H03 0607 *
* *Coding: 000000
* *ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
* *ROD: EV_Immo_UDS_VDD_RM09_SE25.rod
* *VCID: 6AD1F08C8DAC4F6ECF-803E
Address 2E: Media Player 3 (J650) * * * Labels: 5N0-035-342.lbl
* *Part No SW: 5N0 035 342 E * *HW: 5N0 035 342 E
* *Component: SG EXT.PLAYER H13 0240 *
* *Revision: A1001003 * *Serial number: 7662076113 * *
* *Coding: 010000
* *VCID: 2953CF80402A847606-807C
Address 42: Door Elect, Driver * * * *Labels: 1K0-959-701-MIN3.lbl
* *Part No SW: 5K0 959 701 B * *HW: 5K0 959 701 B
* *Component: Tuer-SG * * * * 009 2119 *
* *Coding: 0001204
* *VCID: 316327E0A8FAFCB6CE-8064
Address 44: Steering Assist * * * *Labels: 1Kx-909-14x-44.clb
* *Part No: 1K0 909 144 P
* *Component: EPS_ZFLS Kl. 74 * * 3305 *
* *Revision: 00H22000 * *
* *VCID: 377719F8469E228680-8062
Address 52: Door Elect, Pass. * * * *Labels: 1K0-959-702-MIN3.lbl
* *Part No SW: 5K0 959 702 H * *HW: 5K0 959 702 H
* *Component: Tuer-SG * * * * 009 2105 *
* *Coding: 0001204
* *VCID: 38751AC44B802DFE89-806C
Address 56: Radio (J503) * * * Labels: 5M0-035-1xx-56.clb
* *Part No SW: 1K0 035 180 AE * *HW: 1K0 035 180 AE
* *Component: Radio Prem-8 *H02 0016 *
* *Revision: -----16S * *Serial number: VWZ4Z7M1108183
* *Coding: 01000400040005
* *VCID: 63CF9DA862861E260C-8036
1 Fault Found:
02635 - Tuner Not Enabled/Activated*
* * * * * * 000 - *-*
* * * * * * * * * * Fault Status: 01100000
* * * * * * * * * * Fault Priority: 7
* * * * * * * * * * Reset counter: 88
* * * * * * * * * * Time: 10:18:39
Address 62: Door, Rear Left * * * *Labels: 1K0-959-703-GEN3.lbl
* *Part No SW: 5K0 959 703 D * *HW: 5K0 959 703 D
* *Component: Tuer-SG * * * * 007 2101 *
* *Coding: 0001168
* *Shop #: WSC 01357 011 1012552
* *VCID: 356B13F05C92D09692-8060
Address 72: Door, Rear Right * * * *Labels: 1K0-959-704-GEN3.lbl
* *Part No SW: 5K0 959 704 D * *HW: 5K0 959 704 D
* *Coding: 0001168
* *VCID: 366914FC4194DB8E9B-8062
Address 77: Telephone (J412) * * * Labels: 7P6-035-730.clb
* *Part No SW: 5K0 035 730 E * *HW: 5K0 035 730 E
* *Component: TELEFON * * * H09 2902 *
* *Revision: 1B001001 * *Serial number: 00007661969835
* *Coding: 0A10040000010100
* *ASAM Dataset: EV_UHVNA A01719
* *ROD: EV_UHVNA.rod
* *VCID: 2757C9B85E3EB20610-8072
End-------------------------(Elapsed Time: 02:34)--------------------------
Sent from my XT1254 using Tapatalk
