thatspsychotic
As title states, suspecting RMS leaking due to occasional oil spots on the ground coming from the driver side of the vehicle, and loss of about a quart of oil over 6k miles (145k miles on odometer).
If this is the confirmed cause (will get under the car to confirm when it's a little warmer out), are there other items (preventative/upgrades) that are good to do while the car is apart for the RMS replacement? Does the subframe have to be dropped, meaning adding the Tyrolsport Deadset kit would be synergistic? How much additional labor for adding LSD while trans is already lowered? is that even worth it with so many miles on the car?
Thoughts?
Thoughts?
