Old 04-03-2015, 10:13 PM   #43
troutjunkie
Drives: '12 Golf TDI, '07 Duramax HD
Did you change Byte 18 to 21? You have to do this manually by clicking on the highlighted long coding and entering 21. It's usually 00, or 20. Something like that
2012 4D Golf TDI 3 pedal version, Revo Stage 1, LED Xenon retrofit, Cherry Red LED tails, 18" black motegi 6spokes
troutjunkie is offline   Reply With Quote
Old 04-04-2015, 01:25 AM   #44
Brunkel
Brunkel's Avatar
Drives: 2013 UGM GTI; 6-speed manual
I had a friend do the coding for me since I don't have a cable. I may meet up next week so should be able to mess with it.
I currently have no bulb out errors. We followed the coding everyone was using for the basic xenon upgrade without leds.
Regardless, adding the wire from 4 to 12 makes sense because there was a pin in slit 4 that lead to nothing before (on the ECS adapter at least)
Build Thread
Hi-Def Detailing
Brunkel is offline   Reply With Quote
Old 04-09-2015, 10:21 AM   #45
Brunkel
Brunkel's Avatar
So I know have LEDs without the highline cecm! A couple things to figure out still, they don't come on as DRLs. They only work with the low/high beams. Also, for whatever reason after the new coding my side markers are dimmer.
Build Thread
Hi-Def Detailing
Old 04-09-2015, 10:26 AM   #46
GTIMK6_
GTIMK6_'s Avatar
Drives: GTI Wolfsburg '13
Woooohhhhoooooo! How did you do it man? Coding? We MUST see pictures or it didn't happen!
GTIMK6_ is offline   Reply With Quote
Old 04-09-2015, 10:36 AM   #47
Brunkel
Brunkel's Avatar
I still have some final kinks to work out and then I'll do a full write up on the steps. You can barely tell b/c this was late at night but they are on!
Build Thread
Hi-Def Detailing
Old 04-09-2015, 10:36 AM   #48
Brunkel
Brunkel's Avatar
I just realized we didn't do this maybe that's the reason DRLs aren't on?
Build Thread
Hi-Def Detailing
Old 04-09-2015, 11:05 AM   #49
GTIMK6_
GTIMK6_'s Avatar
This actually could be the reason, what are the drls currently set at?
Old 04-09-2015, 11:06 AM   #50
Brunkel
Brunkel's Avatar
midline to highline cecm swap
They are set as LEDs actually. I had them as fogs before but we changed that.
Build Thread
Hi-Def Detailing
Old 05-01-2015, 06:38 PM   #51
Brunkel
Brunkel's Avatar
So I finally got a Rosstech cable and a Winbook to run VCDS on. Going to mess with the coding tonight to see what I can do!
Build Thread
Hi-Def Detailing
Old 05-02-2015, 12:15 AM   #52
Brunkel
Brunkel's Avatar
It was my euroswitch!!!! I never installed the trigger wire before. I installed that tonight and can now get leds without low beams so they can serve as drls. It's not actually set as drls (can still mess more with the coding I think) but they function as them! So right now it runs as leds, side markers, tails, and license plate. I have the option of doing fogs with that too.
You can do this without the highline. It is possible!
Build Thread
Hi-Def Detailing
Old 05-03-2015, 03:43 PM   #53
GTIMK6_
GTIMK6_'s Avatar
Attachment 48550
Would you please post up a diy on how you managed to modify the harness and the coding?
Old 05-03-2015, 03:44 PM   #54
Brunkel
Brunkel's Avatar
Yep! Plan on doing a new thread on it. Just don't have the time right now but it'll get done!
Build Thread
Hi-Def Detailing
Old 05-03-2015, 03:44 PM   #55
GTIMK6_
GTIMK6_'s Avatar
^ Thanks man!
Old 05-03-2015, 09:48 PM   #56
p4kk0
p4kk0's Avatar
Drives: 12 GTI
Hey I have been running the same setup for a long time with the Midline too. My LED's dim when I use the euroswitch for city lights. Your LED's do that too or they stay at the same brightness between DRL and city? I hope make question makes sense to you.
2012 DBP DSG GTI // 50% Tint // OEM LED Cherry Tails // LED HID Retrofit // DEAutoKey LED Interior // Front Black Emblem //Revo Stage 1
p4kk0 is offline   Reply With Quote
