Hello all, I need some of your knowledge/help. To start out, I have had some trouble with the smoothness of my shifts as of late (since I moved) and have gotten curious as to what I can do to fix it...
The problem I am having (manual btw)...after every shift (especially in shifts 1->2, 2->3, and 3->4) it feels as though I lose all boost...its as if the car is lugging down every time I shift. While in San Diego (much cooler weather, temperature: 70-75 degrees) the shifts were much smoother. I have been in Palm Springs for about 2 weeks and wow...the shifts are terrible. It is also hotter than hell out here (it got to 110 today).
I have also noticed that when the A/C is on, the car does not shift as smooth...but this hot weather has really magnified something and I can't figure out what it is. Do I replace the DV? Will a stage 1 tune smooth the shifts? What can I do so that it smooths out the power delivery?
I took my car to Paradise VW in Palm Desert, CA and asked them to check over the clutch, transmission, etc. and they found nothing (I had to make sure nothing was seriously wrong).
Do any of you from hotter climates experience this? And if so, what is your solution? And...what other precautions are you taking with your car in severe heat? This will be my first summer in Palm Springs with the GTI...
