intellistar
"...But there is also a ''problem'' to find your right engine, because the CCTA engine is only mounted in Golf MK5 for example,
but not in the MK6. Do you have a base hp of 200hp or 210hp?"
Obviously, there could be a bit of a language barrier, but I think the issue is that Sach's (or Michael's department in particular) doesn't know what engine codes are available per region. The website does mention that the clutch kit found here -> http://www.sachsperformance.com/Sachs-Performance-Clutch-Powerclutch/Audi/Audi-A3-8PA-Sportback-09-04-/2-0-TFSI-147-kW-;-CAWB-CCZA-;-09/2004/SRE-Performance-Clutch-Kit::67.html?XTCsid=eccfn4p5j1u4c2jv70bvj1oot6 "...will fit to your original flywheel and releaser" so my guess is that would be the recommendation if you asked "which clutch kit should I buy if using a DMFW?" Regarding 200hp vs 210hp, checking either the page for a 155kW GTI (last link) or 147kW 2.0 TSI, which lists engine codes as CBFA and CCTA, http://www.sachsperformance.com/Sachs-Performance-Kupplung-Sportkupplung/VW/VW-Golf-VI-5K1-10.08-%3E/2.0-TSI-147-kW-;-07/2009-:::2_6_806_4575.html lists the same part numbers, so I'm not sure what difference that would make. I don't foresee myself going back to a DMFW, but it's unfortunate we can't seem to get a clearer answer.
Congrats! Look forward to hearing your thoughts on your setup as well.They told me they would throw in the release bearing for 64 euro (not bad), with a grand total of 654 euro including shipping. That's 734 usd for a full clutch kit. They told me I might have to resurface the flywheel. The shop told me they would decide that depending on how my flywheel looks. So I'm pulling the trigger on this setup tonight.
