Can you guys reliably run that much power on a daily driver?
when jr hit his number it was more of a race tune i believe. he lowered his boost for daily driving.
i don't think that's entirely accurate. I believed JR lowered his boost to take it easy on a turbo that already had over 10k miles on it as he was selling it and wanted to make sure the buyer wouldn't have to worry about a rebuild anytime soon.
Skully DD his 500whp car on race gas and EBC for a while. So there's that too.
MBC not EBC
And boost is still set for kill mod :yikes:
To answer some questions, the car did go from 365 to 484 by just adding Unitronic fueling kit (injectors and Pump) and race fuel mix with 93 oct (and yes we do have 93 oct in PR see the picture below) then we added more pounds of boost and full race fuel and we hit 511whp. Like it was said before the car has gtx3071r with aftermarket rods and pistons stock bore and compression. If you want more info about our shop or built ups go to
Well obviously with injectors you are going to get more power, the question is whether the lpfp was necessary.
Sent from my DROID RAZR using Tapatalk 2
He mentioned Fueling Kit, i assume he meant fueling system Unitronic TSI High Output Fuel System including the lpfp
BAM is mitch,
You seem to know a thing or 2 about this topic. Is it possible to run two different volumes of fuel at the same pressure? Kinda like boost. The bigger turbo guys can run the same psi as us K04's but they have a larger volume of air.
The larger volume of air just allows them to run the same psi at higher engine speeds and also allows them to be at a better spot on the "efficiency island" which results in lower charge temps. Their real power comes at higher boost. The difference between that and fuel is compressibility. Fuel is effectively incompressible. With an incompressible fluid and a fixed volume pump (hpfp) downstream, pressure doesn't matter. So to answer your question, as far as the fuel system on our cars is concerned, with the hpfp in place you can't run different volumes of fuel with the same pressure.
Now, with that said, if you run higher pressure to the hpfp it is possible it would increase the efficiency of the hpfp which would result in more fuel. How much would be hard to say, but it likely wouldn't be much.
so this brings me back to my question from a few pages back
why do they sell the lpfp by itself but to get the injectors you have to buy both?
