NY/NJ/CT/PA VCDS/VAGCOM Locator
2012TP
I need someone on LI with Vagcom to check my timing at idle. Engine feels like its shaking a lot, just need to see whether its the timing chain tensioner or a failing engine mount)
I can do this for ya. Shoot me a PM
SinnedGTI
From the NYC area trying to find someone that can do DSG adaptation, check timing, Roll Window Up/Down with Key, Fogs on with High Beams on, Disabled DRLs
Mainly looking to get DSG adaptation but if you can do the others I'd appreciate it
dynamisoz
Hi. I'm in North bergen and need to check timing chain tensioner value. anyone with vag com in the area?..
dynamisoz
Nelly
Anyone in and around Flushing, Qns. I can travel a bit, cel came on and inspection coming up. Not sure if I should bother with self diagnosis. 65k 2013 dsg.
2012TP
I’m not far away. PM me
CleanAsFckMk6
I live in Doylestown area but work in Center City so if anyone needs something in those areas just send me a msg and let me know
Moce72
Need help in Suffolk county, LI. I'm looking to have my headlights coded to have my demon eyes as my DRL right now it's fogs only.
Smercergt
Need vag-com or similar to erase airbag light after replacing clockspring.
Located in CT. Hartford area. Willing to travel.
Jcway16
Is there anyone in Eastern Long Island that can help me out? I'm in East Setauket
I recently picked up a low mileage ‘12 GTI to use as a fun commuter and it has a couple of issues/faults that I'd like to correct
I picked up an OBDeleven Pro to no avail
2012TP
What are you trying to accomplish with VCDS that OB11 can’t/won’t do?
