I got mostly through this job over the weekend, and a I have a few suggestions for other people who want to attempt it.
-I'm not sure you really need to remove the whole PCV assembly from the top of the head. I did it as you recommended, but it was a pain keeping track of all the bolts, and I only succeeded in having some dust and carbon blow into the open valvetrain when I was blowing out the intake ports. Its probably a preference thing, but if I was doing it again I'd leave it on.
-I would also add that its a good idea to clean your engine really good before you start removing things. My engine was a little grungy after 66k miles, and I didn't think much of it, but as soon as I took off the intake manifold some crud that had built up in the seam between the mani and the block got loose fell into the intake ports. I don't think any got into the cylinders, but I can imagine if you had any kind of sand or road grit fall in there that could be big trouble.
-I don't know if the '10 configuration is different than most, but I don't think you mentioned removing the oil filter. I tried to pull the manifold off while the filter was still on and it took a lot of "convincing" to get it slide off the pins. This also left a big dent in the side of my oil filter. Since the filter is normally dry at rest its no big deal to pop it off. Gives a lot better access to that side of the manifold anyways.
As for my particular job, it took me about 3 hours to get the old one off.
I had the hardest time getting the Throttle-body hose off, because of the way the hose clamps were turned, and the fact that I didn't have a compact 7mm wrench.
And I didn't have the long 1/4" extension bar, or a deep socket big enough to reach all the head bolts, so I had to get them the hard way.
All-in-all it was a major pain, but I followed the instructions and eventually got it off.
The replacement went in a little easier, but since I was rushing, something in the fuel system didn't get seated properly.
The car started and ran fine once the air got purged from the fuel lines, but it also started spitting out fuel. I couldn't tell if it was the hardline or the injector seals themselves, but I'm gonna have to pull everything off again and take a closer look tonight.
I know dbestgti keeps talking about changing out the seals, so maybe that is what I'll have to do, but for now I want to make sure it is a seal problem, and not a workmanship problem.
All-in-all I would call this a fairly difficult job. Especially if you don't have a very complete tool set.
I wouldn't even attempt this unless you have the correct extensions, the triple-square bits, and the small metric deep-sockets.
It can be done without them, but it makes an already tricky job a very big PITA
