There are some significant differences between VP Racing MS109 and Sunoco 260GT and aren't really considered 'pump gas' equivelents.
Pump Gas
Stoichiometric Air/Fuel Ratio: 14.7
Specific Gravity: 0.740-0.770
Oxygenated: 0%
Sunoco 260GT
Octane ((R+M)/2: 100
Stoichiometric Air/Fuel Ratio: 14.1
Specific Gravity: 0.734
Oxygenated: 0%
VP Racing MS109
Octane ((R+M)/2: 105
Stoichiometric Air/Fuel Ratio: 13.41
Specific Gravity: 0.722
Oxygenated: 9% (just googled,not 100% confirmed exact %)
There are 3 major things to pay attention to with these fuels, stoich, specific gravity and oxygen content.
- The lower the stoich value, the more the fuel system has to supply to achieve the target lambda value.
- The lower the specific gravity, the more fuel needs to be sprayed to match the fuel mass the vehicle was tuned with.
- The more oxygen in the fuel, the more fuel needs to be sprayed to compensate for the oxygen that makes its way into the combustion chamber via the fuel. Generally the percentage of extra fuel that needs to be supplied closely matches the percentage of oxygen in in the fuel. This can be helpful for power though, especially on a turbo that is flow limited like a K04.
As you can see, MS109 makes the fuel system have to supply more fuel than 260GT in all 3 categories. This is fine on a fuel system that is healthy and has the additional headroom to make up this difference with fuel trims. On a system that is close to being maxed out (fuel pump flow capability, fuel injector duty cycle, clogged fuel filter,etc...) you can max out the fuel trim and run the risk of running dangerously LEAN. If you run lean, the cylinder temps can get WAY hot. Enough to melt stuff, spark plug electrodes or exhaust valves, for instance.
If you are going to run this fuel or anything other than Sunoco 260GT I highly suggest logging your target/actual rail pressure, target/actual lambda values, instantaneous fuel trim and long term partial fuel trim to make sure the fuel system has enough headroom to safely supply the necessary fuel. Better safe than sorry.
Vag-Com Blocks
230-1 Target Rail Pressure
230-2 Actual Rail Pressure
031-1 Actual Lambda
031-2 Target Lambda
032-2 Long-Term Fuel Trim (partial)
033-1 Instantaneous Fuel Trim (Short-Term Fuel Trim)
