#1 |
Induktion Motorsports I flow for TDI
We have TDI intakes Stage 1 is ready to go. Stage 2 in final testing. Feeler for who would want one or might be interested?
Click Here for more details. |
#2 | |
![]() Drives: 2012 Golf TDI Black 4dr DSG Join Date: Sep 2012
2012 Black Golf TDI 4DR 6-Speed DSG, Sun & Nav Package | OEM Mudflaps | OEM Body Side Moldings | Neuspeed Turbo Discharge Damper | Color Matched Sidemarkers | ECS Blue Aspherical Blind Spot Mirrors | Rear /// Badge | 25F/5R Black Charcoal Tints | |
#3 |
![]() Drives: '12 Jetta 2.5 SEL; '14 328D xDrive Join Date: Apr 2010
Do you have some pics of the actual TDI intake? Curious as to how it looks.
-Jason G. -- 2012 Jetta 2.5 SEL 2014 BMW 328D xDrive |
#4 |
#5 |
#6 |
![]() Drives: 2012 Golf TDI w/DSG Join Date: May 2012
Any Numbers? Or is this just a fancy way to say, "Hey listen to my Diesel Turbo SQUEAL and HISS!"
Don't mean to sound rude, but for 200 bucks, it better give me at least 20 HP and 30 TQ... 300 bucks more and I can have a Malone State 1.5 Tune and it'll bump the hp up about 50 and the Torque up about 105. Looks purty though... The Gas Cars make some decent numbers with intakes, but Diesels don't really since the Throttle Body is non existant and the power is controlled by fueling and turbo boost. Now if you can design and Turbo to Intercooler to Intake Manifold set up that could smooth out airflow, we might see some gains if it is coupled with this intake.
"Yo Kate, where do you keep the casserole dishes? (Why?) The cat won't fit in the toaster." ALF Last edited by 85RedGolf2.5; 07-19-2013 at 03:29 PM. |
#7 | |
#8 |
![]() Drives: 12 TDI 4dr 6sp, APR 1, SnowPerf W/M Join Date: Jun 2013
I'm interested in some commentary on a few of the posts over on this thread in the TDIClub forum: http://forums.tdiclub.com/showthread.php?t=290373
In particular, there are a couple of statements which seem to make sense to me, and have thus far stayed my impulse to invest in an after-market intake system (pending further investigation), which I would like some feedback on. I'm paraphrasing here, but these are two key points which stick out to me: The OEM filter seems to do a better job of removing particulate matter from the intake than most non-paper hi-flow filters. This seems to make sense to me for obvious reasons: paper filters usually consist of more densely packed fibres, which corresponds to an increased ability to filter out more and smaller particulate matter from the intake. Obviously, more densely packed fibres means more restricted airflow, which is the normal compromise one has to balance with any air filtration system, but this brings me to the next point: The OEM filter, in the case of the TDI anyway, is NOT a performance bottle-neck due to its enormous surface area. Again, this seems to make sense to me. Anyone who has seen how big the OEM air filter on the 2.0 TDI is, knows it's massive, especially compared to the OEM filters of similarly sized/powered motors. The bigger the filter, the more air it can flow. From what I've read/heard, it doesn't really sound like the average person is going to get close to running into airflow restriction issues on the intake, especially if they still have a with a stock turbo. That said, I can understand why some folks might forgo the OEM air box for space savings reasons. My only other concern, and this has nothing to do with the other thread, is that it seems like you've got the intake configured such that it's essentially pulling in air from inside the engine bay as opposed to fresh outside air, like in the OEM configuration. Can you please explain this? I may be wrong here, but my current understanding leads me to believe that air from inside the engine bay is not only warmer than ambient air, but also at speed it's at a lower pressure than the air you'd get from outside. Lower pressures and higher temperatures usually corresponds to decreased air density, and therefore more work for the intercooler. Wouldn't you want to stick to a similar-to-OEM design which pulls outside air instead so that you can improve the charge density? I appreciate the feedback in advance! Thank you! ![]() Last edited by jade eyed wolf; 07-19-2013 at 01:37 PM. |
#9 | |
![]() Drives: MK6 Golf TDI Join Date: Oct 2012
and second, an intake will not enhance performance for the tdi. the stock intake handles ~400hp. intake is not restricting hp. people buy intakes for TDi for the sound and aesthetics. |
#10 |
I will have to read up on the thread over in the TDIclub some more over the weekend but to be clear we do not use wet(oiled) filter elements for they are prone to foul out MAF sensors. The air filters we use are AEM Dry filters. But to answer your question about the warm air. If you enlarge the picture you will see there is a rubber seal on the left hand side of the air box. That is to seal from the engine bay. On our TSI's that we have already in mass production we saw a drop in IAT's with the intake and of course more power. The piece of the airbox that is in the grill still will feed air into the intake. As we start moving forward I will keep all these questions in my head to give better and accurate information of not only why it works but how.
#11 |
#12 | |
Stage 1.5 158whp (179bhp) / 290lb-ft (328lb-ft crank) Son, You Got jipped... This is the Stage 1 153whp (173bhp) / 287lb-ft (324lb-ft crank) And Stock 133hp/225lb-ft
"Yo Kate, where do you keep the casserole dishes? (Why?) The cat won't fit in the toaster." ALF |
#13 | |
I was on the money when I said 25whp increase. |
#14 | |
Tags |
i flow, intake, tdi |
Display Modes | |
