Uberryan
Banned
Well how about another post from me about another issue...
Went to go clean my intake filter, and check my O2 sensor and found these transmission bolts lying just like so. My long block was replaced under warranty back in May/June due to a bad bearing making some funky sound on acceleration, and these bolts hold the tranny to the long block, clearly.
Since I've driven the car like a mad man since then, is there any possibility of damage resulting from what I assume is just these two bolts not installed?
I called the dealer who did the job, explained to them what I found and they sounded pretty horrified. I asked if they wanted me to try and install the bolts and take it by tomorrow, and they gave me the ok. Lucky I did my brakes last year because the bolts have a weird hex pattern that fit none of the 5000 sockets I had, so I resorted to using the M14 triple square needed for the rear rotor replacement, and it fit like a charm. Notched them down as much as I could without trying to over-torque them. Seem to be pretty tight. Car goes to the dealer first thing in the morning.
